element14's The Ben Heck Show
Forum PSP Mod Idea
  • Subscribers 33 subscribers
  • Views 910 views
PSP Mod Idea
teefarocks
teefarocks over 13 years ago
I was wondering if any one can help me with my idea ?
The idea is to use a bricked psp and recreate a new software for it as to use it as a portable laboratory instruments which this device will include an oscilloscope and a DSP analyzer where you can manipulate signals by applying different types of filters on it and also it will include a normal multimeter in it and last spectrum meter as to display the signal in it frequency domain.
If any one can help me this will be great, I want to point that I'm a communication and information engineer with good skills with designing hardware logic circuits and also good with programming with low level language like assembly and C programming.
If you liked my idea you can contact me anytime
  • Catwell
    Catwell over 13 years ago +1 suggested
    When you say bricked, what happened? The screen is still useable, I assume. And the case/controls. You may have to replace the main board. Using the screen is nothing new: http://www.instructables.com…
  • Catwell
    0 Catwell over 13 years ago
    http://www.instructables.com/answers/I-Need-Help-Connecting-a-PSP-Screen-to-my-Arduino/
    http://hackaday.com/2009/12/12/fpga-driver-for-psp-screen/
    It's the rest of what you want to do that is the challenge...
    C
  • teefarocks
    0 teefarocks over 13 years ago in reply to Catwell
    Thanks for ur replay but i was thinking if i just can reprogram the bootloader in the psp and start building the OS cause  when i faced this problem i noticed that unbricked means that it cannot boot, from here the idea came to me and also i'm trying to use the existing components and the wiring cause i think i won't be able to do much better.
    So if you can help me this will be great and you can contact me on my mail if you like.
    mail :
    mustafa.faisal.eng@gmail.com
  • jds123
    0 jds123 over 13 years ago in reply to teefarocks
    It would be very hard to do what you would like to do because you need to know the machine code for the PSP, and nobody wants to do that because it is too much work. youre probably better off trying to copy a bootloader from another psp.
  • benheck
    0 benheck over 13 years ago
    You're best off using the screen which is well documented.
  • Catwell
    0 Catwell over 13 years ago in reply to teefarocks
    Mustafa,
    Check out PSPMOD.com - all answers can be found there.
    http://www.pspmod.com/forums/forum.php?s=2d911a73f4aee22aaa3e60d9b3ebb98e
    C
    pcb (program control board) , 'c' language prog. converte byte code to machine language control use in pcb
    [url=http://www.Champion-Commercial.com/]commercial real estate raleigh nc[/url]
