element14's The Ben Heck Show
Forum Digital RGB (TTL) to VGA or HDMI
  • Subscribers 29 subscribers
  • Views 2920 views
  • mod
  • hardware
  • build
  • build_challenge
  • viewer_challenge
  • show_idea
Hi Ben! Great stuff I've seen you do in your videos. So maybe you can help with this.  I have a Roland S-550 Digital Sampler. I works great, via the monochrome output on the back of the unit. Yet, it is in grayscale. Is there a way to create a converter for the Digital RGB output so the sampler can be used with a VGA or HDMI video output?  The most important feature I would gain is being able to edit my data via a color interface, This would make it easy. Yet, I've found out that the Digital RGB output is using TTL. This is an old standard. Here's a link to an older schematic of a cable Roland made years ago.  http://www.chezrossi.net/s760/images/rgb25i.gifhttp://www.chezrossi.net/s760/images/rgb25i.gif   Here is another link to a newer model made by Roland, but still have the same video outputs.
http://myweb.tiscali.co.uk/clouzeau/s760/monitor.htm All of the links show what would have been used.But, this stuff is discontinued. I don't want to throw it out because it's a great machine.  Thank you in advance for your help.
Dante'
    Found this schematic on the web, hope it helps
    Lloyd - DigiTek
    llsdigitek@gmail.com
      To: Lloyd Smith
      Sent: Friday, August 16, 2013 7:54 AM
      Subject: - Digital RGB (TTL) to VGA or HDMI
            created by Dante Pettus in The Ben Heck Show - View the full discussion
    Lloyd,
            I also found out that the TTL refresh rate is slower than VGA. I
    think its about 15.35 khz, though not sure.  Will the schematic you send me
    allow the TTL to be viewed on a VGA screen?  Please advise, thanks.
    Dante Pettus
    Lloyd,
           I found out more data...
    Signal
    TypeDigital, TTL
    Resolution640h × 200v, 320h × 200v
    H-freq15.75 kHz
    V-freq60 Hz
    Colors
    16
    Once agai, thanks for your help.
    Dante'
    From what I gathered it takes the TTL and converts it.
    That being said there are adapters available from china
    if you enter a search into www.amazon.com AND
    ebay too...  Truthfully I have never done this myself
    just relaying what I'd found in a quick search on the web.
    Lloyd
