element14's The Ben Heck Show
Forum I want to build a car parked detector for my garage
  • Replies 17 replies
  • Answers 2 answers
  • Subscribers 34 subscribers
  • Views 1942 views
gez
gez over 13 years ago
Does anyone know how those car detectors work in shopping center carparks? You know the ones that show a green or red light depending on whether a car is parked in the space. I want to make one that will tell my phone if a car is parked in the garage or not. I was thinking of using an arduino connected to a"Ultrasonic Module HC-SR04 Distance Measuring Transducer Sensor for Arduino measurer" to measure the distance from the ceiling to the floor/top of the car, but someone said they thought they worked by using a magnetic field.
Gez
  • colecago
    0 colecago over 13 years ago in reply to gez
    Gerry Knight wrote:
    That's too simple, I would have nothing to do then image
    That is true, but sometimes its good to offer the cheapest fastest solution if it already exists.  Sometimes the point is learning and making, sometimes the end goal is the point.
    0 mcb1 over 13 years ago in reply to gez
    Gerry
    Yes that explains it perfectly ....
    I have no further advise except to take it on the chin, and add GPS tracking to the better half.
  • benheck
    0 benheck over 13 years ago
    A 38KHz detector could work, but sometimes they're TOO sensitive. Think of your TV remote, which works even if you bounce it off your eyeball or teeth.
    Ultrasonic sounds like a good bet! You can get distance with that too, not just blocked/unblocked.
  • gez
    0 gez over 13 years ago in reply to benheck
    Yeah, I have decided to try using two ultrasonic measurers, a RGB LED and an arduino; I will use one sensor to detect if a car is parked in the space, the other to detect if a car parks in the driveway. I'm thinking that I can use some logic like:
    The driveway sensor detects that a car has entered the driveway because the distance to the driveway has shortened by x amount from y, and remains shortened for longer than z seconds. This should prevent false positives caused by someone walking past the sensor.
    Read the sensor in the garage to determine if a car is parked there.
    Flash an RGB LED on the garage door for a predetermined number of seconds, green if no car is parked there, red if there is.
    Reset the sequence when the distance to the driveway returns to its default y value.
    Sounds simple image If my sensors arrive soon I might get it done this weekend!
  • gez
    0 gez over 13 years ago in reply to mcb1
    Gerry
    Mapping out how it should work is the first part of the puzzle, and is often missed by newcomers to programming.
    I suggest using the millis() for timing rather than delay() as it allows you to continue doing other things.
    It should be a good project, and you should start a blog, to allow others to follow.
    It doesn't need to be a single, it can have additions made as you solve issues, add features.
    (unfortunately its last in at the top, so following it works from the bottom)
    eg http://www.element14.com/community/people/mcb1/blog/2013/08
  • jeffclough
    0 jeffclough over 13 years ago
    Gerry,
    There are a number of proximity sensors available from Adafruit. (No, I'm not connected with them. They just have cool, hobbyist oriented stuff with good instructions.) Check out http://www.adafruit.com/category/35_57.
    --Jeff
