element14's The Ben Heck Show
Forum screen compatbility
  • Replies 21 replies
  • Subscribers 31 subscribers
  • Views 2126 views
screen compatbility
royston02
royston02 over 12 years ago
I am planning of making a portable computer with raspberry pi. I found a touchscreen display for a olinuxio board. But since I am new to the electronics world, I don't know so much to reverse engineering, so if anyone out there can help me, so can you tell the steps?
  • colecago
    0 colecago over 12 years ago
    Do you have a link to the screen?
  • royston02
    0 royston02 over 12 years ago in reply to colecago
    The link is- http://in.element14.com/olimex/a13-lcd7-ts/touchscreen-7inch-tft-for-olinuxino/dp/2308269
  • colecago
    That screen is digital RGB, you will have trouble interfacing it with the Pi
    RGB digital[edit]
    A HDMI/DIV to parallel 3.3v interface PCB, also meant for the Beagleboard:
    http://www.harbaum.org/till/dvi2par/index.shtml
    Potential interfacing chips:
    They emit Hsync, Vsync and RGB w/ about 8 bits each (sometimes, it's called "MIPI DPI")
    • Toshiba TC358762XBG deserializer bridge chip
    • Analog Devices HDMI Receivers
    • Renesas µPD60800 Intelligent Buffer IC
    • Renesas µPD60801 Intelligent Buffer IC
  • royston02
    I find it to difficult. Can anyone suggest a easier way to add touchscreen? It is because I am a begginer.
  • colecago
    0 colecago over 12 years ago in reply to royston02
    These are the cheapest I've found
    http://www.chalk-elec.com/?page_id=1280#!/~/category/id=3094861&offset=0&sort=priceAsc
  • royston02
    BUT they are out of stock
  • royston02
    I found this screen. Can anyone give suggestions regarding it and RPI and how to make it run of 5V.
    http://www.ebay.com/itm/New-7-TFT-Color-LCD-Screen-Touch-Key-Car-Rear-Monitoring-Waterproof-Black-/130968566266?pt=GPS_Devices&hash=item1e7e55b9fa
    Royston.
  • colecago
    Should be pretty easy, it uses composite which the Pi outputs, get a DC supply capable of 12V for the screen then get a regulator to give you 5V from the 12V for the Pi.  It's exactly like using the 3.5" screen Ben used on the Portable Pi project.  BTW, this one is cheaper
    http://www.amazon.com/Camera-Monitor-Support-Rotating-Screen/dp/B007SLDF7O/ref=sr_1_1?ie=UTF8&qid=1387376052&sr=8-1&keywords=7%22+backup+screen
  • royston02
    Is thre some way to make run of 5V? Plus I need it to be touchscreen.
    Royston.
  • colecago
    Some of the screens work on 5V, but most require 12V.  You can use a boost converter to get 12V, or you can provide 12V and the use a linear regulator or a buck converter (switching regulator) to get 5V for you Pi.  Also, that screen you posted is not a touch screen.
