element14's The Ben Heck Show
Forum Portable Vehicle Backup Screen Problems
  • Replies 9 replies
  • Subscribers 30 subscribers
  • Views 842 views
So I followed Ben's link to the backup cameras on Amazon and I ordered two of them. I am waiting for my raspberry pi to arrive in the mail. In the meantime I was trying to build a PSone portable and was  going to use on of the screen for it. However, when I hook it up to the playstation I have issues. It will display the Sony loading screen just fine as well as the memory card/cd select screen jus fine. However, when I start to play a game on it, the image continually scrolls up on the screen. I guess it is a vertical sync problem, related to improper frequency matching between the console and display? Does this make sense and is there anything I can do to make it display the playstation images properly?
Also, will this be an issue with the raspberry pi?
  • colecago
    0 colecago over 12 years ago
    Do they both do this?  What voltage do you have applied to the screens.
    I've never had this problem with the Pi yet, you don't have anything connected to the white do you?
    Maybe its some type of resolution issue judging by it only happening in game?
    PSONE NTSC Display Resolution
    | Mode | Resolution (H x V) | Scan |
    | 0 | 256 x 240 | |
    | 1 | 320 x 240 | Non-Interlaced |
    | 2 | 512 x 240 | |
    | 3 | 640 x 240 | |
    | 4 | 256 x 480 | |
    | 5 | 320 x 480 | Interlaced |
    | 6 | 512 x 480 | |
    | 7 | 640 x 480 | |
    0 e14 Contributor over 12 years ago in reply to colecago
    Both screens do this. Same problems with 7.2Vdc to 12Vdc input. Only have the yellow and power connected. White is floating.
  • colecago
    0 colecago over 12 years ago in reply to e14 Contributor
    Not sure, do you have any other things that have that output to test?  I believe SVideo can be converted to composite
    I tried my YOBO NES knock off and same thing, scrolling screen. It does display  the video correctly, it just continuously scrolls.
    I noticed on his episode where he makes the portable Atari he has to modify the resistor ladder to be compatible with the "newer" screen. Anyone have a schematic of what that change was?
    Sorry the Atari is straight RF out. So that really doesn't apply to this issue.
    I wish this had adjuster knobs so I could match up the vertical sync and "tune" the screen.
    The video image on the screen is perfect when hooked up to my dvd player. What is different about video game signals?
  • colecago
    Not sure, that's why my thought is something resolution related by the fact that it changes when you start a game.  Maybe something about interlaced vs non?
    I have noticed the same problem when i tested the screen at my de/at-PAL NES. So i connected itnto my Pi-B(512) and ran omxplayer. Works perfectly! I haven't tried, but you may be able to solve scrolling problems when selecting screen ratio in the settings menu
