element14's The Ben Heck Show
Forum A question to Ben about soldering iron maintenance
  • Subscribers 29 subscribers
  • Views 589 views
  • maintenance
  • iron
  • ben-heck
  • soldering
  • question
makerimages
makerimages over 12 years ago
Hey there! A long time viewer, first time writer.
I recently got my 3rd solderig iron, it had a chisel tip and a sharp tip, My first irons tip lasted for about a year, the second ones didnt last for a day... image
And I managed to ruin the chisel aswell.... the first and second ones can hopefully be filed down to a point where i can retin the copper core. I'm going to get this solder in March: https://www.elfa.se/elfa3~ee_et/elfa/init.do?item=82-489-79&toc=0&q=wire+spool
From what I have seen on the interwebz, the easiest way to use a tin that has flux in it for the first time tinning the tip is wrapping some wire around the tip, before plugging it in. Will that work? And what are the general guidelines for making a tip last long? I think this topic is important enough to maybe get an episode of TBHS on it?
    Filing down a soldering iron's tip scratches the cladding and exposes the inner material, which can make your iron degrade early. Properly tinning the tip when it first heats up and burns off the temporary shipping coating and then each time you use it only requires touching the tip with the solder itself once the iron is warm enough to melt the solder. Make sure to clean the tip (wet sponge, etc) to avoid pitting from too much resin if you are using cored solder or powdered flux.
    Kirk
    No you do not want to file the tip. That will make your iron degrade early. I would definetly recommend reading up on soldering iron tip tinning and care. It is really important to take good care of your soldering iron and tips otherwise you will keep burning through them and well that's a bit expensive and I'm sure you would like to save that money in the long run.
    For sure when you get the new iron tin the tip right away before using it. Then make sure you clean the tip as you go or right after you are done soldering.
    This is a pretty good article on soldering tip care: Solder tip tinning and care. | Production Automation Station.
    Good luck!
  • makerimages
    0 makerimages over 12 years ago
    Phew, I finally took up the courage to attempt to tin the conical.. worked great with that new solder image Now I can continue work on my Z80 based SBC.
