element14's The Ben Heck Show
Forum USB
  • Subscribers 30 subscribers
  • Views 480 views
USB
royston02
royston02 over 12 years ago
I was wondering if you could get 11 V of 2 USB ports.
  • colecago
    0 colecago over 12 years ago
    Yes, boost converter
    http://www.pololu.com/product/2571
    Pololu - Step-Up Voltage Regulators
  • royston02
    0 royston02 over 12 years ago in reply to colecago
    I found this one
    -http://www.ebay.in/itm/LM2587-Step-Up-Booster-DC-DC-3-5V-30V-4V-30V-5A-Voltage-Regulator-Adjustable-/221113744315
    Input voltage is 3A. I don't think a usb port can supply that much
  • colecago
    0 colecago over 12 years ago in reply to royston02
    A USB port on a computer is typically limited to 500mA unless the device is intelligent, talks to the computer, and requests more.  Standalone USB wall supplies or even powered hubs can support more, you will need to look on the specific device to see what it supports.  It is not uncommon for a USB wall supply to support 1-2A.  As for the 3A requirement, that is based on what you are using at the output
    Input Voltage * Input Current * Efficiency = Output Voltage * Output Current
    For example lets say you want 11V at 1 A and your converter is 85% efficient
    5V * xA * .85= 11V * 1A
    Input current xA = 2.58A
    Switching regulators are power converters, so power in = power out, minus some for not perfect efficiency.
