element14's The Ben Heck Show
Forum Fried Raspberry Pi
  • Subscribers 32 subscribers
  • Views 1191 views
  • fried
  • raspberry
  • help
  • pi
  • raspberrypi
  • ben-heck
  • heck
  • ben
Fried Raspberry Pi
blueokiris
blueokiris over 12 years ago
Is there any way to fix a fried raspberry pi? I accidentally sent 9.6v into the 5v pin. Can I fix this or at least get it to turn on? Or do I have to buy a new one? Please Help Me!
    For the first part, no, you can't fix it. To get a new one, go to newark.com and search "Raspberry Pi." You will find it.
    Hope this helps.
  • kas.lewis
    0 kas.lewis over 12 years ago
    It really depends what got fried, and how good your soldering skills are. I have fried uC before and just replaced them saving myself $30+ in the process but they are not really the easiest things to replace. If you fried the voltage regulator, that is simpler to fix as they generally only have 3 - 6 pins. I would try look at the schematic and see what may have blown (i.e. what is connected directly to that pin and check those components, they may be shorting). Good luck and I hope you get it working again
  • johnbeetem
    0 johnbeetem over 12 years ago
    RasPi tries to protect herself from overvoltage on the 5V pin.  Specifically, protection zener diode D17 switches on and clamps TP1 to a bit more than 5V.  However, D17 can only take so much power before it melts and either shorts out or opens.  If you're powering RasPi from the Micro USB input, the excessive current through D17 trips polyfuse F3 and stops the current.  If this is what happens, wait for F3 to reset itself in a few hours or days.
    If you hit a 5V pin on the GPIO connector or TP1 with 9.6V, you've probably destroyed D17.  Take a look at it and see if there's any evidence of magic smoke being let out.  Then check TP1 to TP2 with an Ohmmeter with power off.  If TP1 and TP2 are shorted, you may be able to fix RasPi by replacing D17.  But look elsewhere for evidence of "magic smoke".
    Did you have any 5V devices like HDMI or USB devices hooked up?  They may have been damaged by 5V if D17 didn't protect you.
  • blueokiris
    0 blueokiris over 12 years ago in reply to kas.lewis
    Thanks, but I would probably be better off salvaging the ports and other parts and buying a new one. I am not a very good solderer.
  • blueokiris
    0 blueokiris over 12 years ago in reply to johnbeetem
    No I was smart enough not to put anything in while I was doing anything, and luckily the overall board wasn't damaged. I think that is probably what I did. There are faint traces of magic smoke, but the device itself started smoking near the power input as soon as a touch a wire to the pin.
    0 e14 Contributor over 12 years ago in reply to blueokiris
    Odds are, if you can get it to boot, it should work.
