element14's The Ben Heck Show
Forum how to how do you connect a 7 inch TFT Color LCD Car Rear View Camera Monitor Support Rotating The Screen and 2 AV Inputs to the raspberry pi
  • Answers 2 answers
  • Subscribers 31 subscribers
  • Views 2734 views
  • rasperry_pi
I  just got the raspberry pi how do I set up the monitor it came with a 3 bare wires
  • royston02
    0 royston02 over 12 years ago
    You should connect the yellow(composite) to the RPi. The others should be left bare.
  • royston02
    0 royston02 over 12 years ago in reply to royston02
    Some other things you may be interested in:
    -http://www.raspberrypi.org/phpBB3/viewtopic.php?f=45&t=67450
    -http://www.wisegai.com/2012/11/29/raspberry-pi-using-a-3-5-tft-car-monitor-optional-powered-using-usb/
    -Raspberry Pi • View topic - 3.5 TFT Lcd Screen Problems.
    0 Former Member over 12 years ago in reply to royston02
    tried that but i think i need a power supply any ideas
    0 dougw over 12 years ago
    Hi Emily,
    My rearview monitor came with 3 connectors on the cable - White, Yellow and Red.
    The Yellow and White RCA connectors are both video inputs - you can connect the R-Pi  composite output to either of these.
    The Red connector is  a barrel jack for power - it requires a DC power source which can be any voltage between about 9V and 15V - where the outer barrel is ground and the inner pin is positive supply voltage.
    The display doesn't do anything until power is connected and there is a valid video signal on one of the inputs.
    I hope this helps...
    Doug
  • benheck
    0 benheck over 12 years ago
    Some 7" monitors have HDMI support - you'll get much better video with one of those.
