element14's The Ben Heck Show
Forum Arduino hack
  • Subscribers 30 subscribers
  • Views 720 views
Arduino hack
royston02
royston02 over 12 years ago
I found a atmega324PA in a multi-rotor control board.
-Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking
It has an ICSP header. So I had 3 questions
1)Can I erase the memory using the ICSP header
2)Can I write to it an arduino bootloader
3)can I program it using ICSP
Also I'm using this because it's LCD broke in a crash, so I was hoping to take the chip and use i has an microcontroller
  • royston02
    0 royston02 over 12 years ago
    Also only the screen is broken and pins are bent but everything else is okimage
  • royston02
    0 royston02 over 12 years ago in reply to royston02
    No ideaimage??????????????????
  • vish
    0 vish over 12 years ago
    Two questions :
    1. How you are sure it's an arduino? Just by seeing the hardware or some other logo was there?
    2. What kind of package is the AVR IC?
    If it's a DIP, you can remove it from the board and try using Parallel programmer to upload bootloader. Check here : http://arduino.cc/en/Hacking/ParallelProgrammer
    If it's not, u have to try the ICSP header. Instructions are here : Arduino - Bootloader
  • royston02
    0 royston02 over 12 years ago in reply to vish
    It's an atmega324pa smd chip not arduino. I wanted to know if I could remove it from the board and use in my own projects.
  • vish
    0 vish over 12 years ago in reply to royston02
    I think you can. It's listed in the webpage :
    The 6 Pin USBasp AVR Programming interface ensures future software updates will be quick and easy.
    So technically you should be able to upload any hex/bin files to that.
    One problem you may face is with the bootloader. As far as I know 324 bootloader is not available officially( may be wrong ), but after a quick googling I found these links interesting
    http://forum.arduino.cc/index.php?topic=53600.0
    http://forum.arduino.cc/index.php?topic=103623.0
    Check that!
    Again you need to have a USB to TTL level converter in future to upload the sketches from arduino IDE.
