element14's The Ben Heck Show
Forum rasberry pi error
  • Subscribers 32 subscribers
  • Views 638 views
  • ben_heck
rasberry pi error
balab
balab over 12 years ago
hi ben
i deed help for your mobile rpi  my rpi donot have rca out signal  firs boot from hdmi all comfig.txt chensigs not working plise help ( sory for my bad english)
  • kidiccurus
    0 kidiccurus over 12 years ago
    Make sure your screen works. Try testing it on your Tv instead.
    TV out can be tricky on the PI. IF you have the HDMI cable connected the PI will always default to that so be sure to unplug your HDMI cable. If you still don't get a signal through the RCA connector then you need to check the following
    cd to /boot
    sudo nano config.txt
    Make sure the line "sdtv_mode=0" is in the file if you are in North America
    Save and Close , reboot and disconnect the HDMI cable
    Look here if you are still having problems
    http://elinux.org/RPiconfig#Video_mode_options
  • balab
    0 balab over 12 years ago in reply to e14 Contributor
    I TRY THAT NOT WORKING   IBY AN HDMI DYSPLAY
  • royston02
    0 royston02 over 12 years ago in reply to balab
    Try these
    -Raspberry Pi • View topic - NO COMPOSITE VIDEO, need help!
    -Raspberry Pi: Using a 3.5″ TFT Car Monitor (optional: powered using USB)
    -composite video - How to override config.txt settings during boot? - Raspberry Pi Stack Exchange
