element14's The Ben Heck Show
Forum building a quadcopter
  • Answers 2 answers
  • Subscribers 31 subscribers
  • Views 636 views
hey i know you guys are great
I would like to build a quad copter i am 15 and in to fixing computers and other pieces of technology and i have loads of pc fan lying around i was wondering if i could maybe build a quad copter with these and maybe an old mother board or raspberry pi
thanks for the help
kallum
    e14 Contributor over 12 years ago +1 suggested
    Hi Kallum, John is right. You will need special propellers, motors and controller in order to build a quad. I propose you to start with a almost ready to fly kit or follow a tutorial like this one http…
    0 jw0752 over 12 years ago
    Hi Kallum, The motors that are used for cooling in computers are not designed to handle the power necessary to allow them to lift themselves. You would burn them out with too much voltage before they would produce lift. They are also designed without attention to their weight. You will need a DC motor capable of handling sufficient power with a propeller designed to produce lift. The raspberry if programmed properly certainly could control the flight. As far as components from computer circuit boards being useful well the best course of action would be to get a design for your copter and then see if there are any parts on your computer boards that will fill the component needs.
    Hi Kallum,
    John is right. You will need special propellers, motors and controller in order to build a quad. I propose you to start with a almost ready to fly kit or follow a tutorial like this one http://blog.oscarliang.net/diy-mini-quadcopter/
    Nikolay.
  • royston02
    0 royston02 over 12 years ago in reply to e14 Contributor
    You will require motors, esc's battery(with charger) and I recommend a multirotor board to a RPi.
    -http://www.instructables.com/id/Scratch-build-your-own-quad-copter/
    -http://hackaday.com/2011/07/27/how-to-build-your-own-quadcopter-step-by-step/
    thanks for the help guys if i get this done i will post the finished result here
