element14's The Ben Heck Show
Forum How Do You Solder without Flux?
  • Replies 12 replies
  • Subscribers 31 subscribers
  • Views 6115 views
  • soldering
How do you solder without flux?  I see people do it and the solder connections look solid and shiny.  I know that using leaded solder makes it easier, but I still need to use flux in order to get that solid and shiny connection.  I've heard that using solder with a particular ratio of flux to solder is important.
    0 e14 Contributor over 12 years ago in reply to michaelwylie
    Yes, absolutely (said with a huge smile on my face)!!!  I only changed the tip from 800F to 600F and it worked great.  There was only a little smoke when I added the solder to the joint and no sputtering like it did before.  The solder just melted and spread like it should.  I now make sure I tip the tip after each use.
    I think I do want to try solder with different flux in the core. I'm wondering if there is a solderability trade-off if I use a no-clean solder.
    good luck =)
