element14's The Ben Heck Show
Forum A cheaper way to make a video game cartridge?
  • Replies 9 replies
  • Subscribers 31 subscribers
  • Views 952 views
I'm developing a video game console and trying to figure out a way to bring cartridge games back.  Partly for retro reasons but also because they have faster loading times as well as being more sturdy and reliable.  The main reasoning of video games switching to cds is because they hold bigger files and is cheaper to manufacture.  I know these days sd cards can hold much more then blu-ray disk.  Even the modern high end video games are up to 32gb so I won't need a card bigger then that.
With that said, I'm curious if I can develop a cart that would cost $5 each compare to $1 blu-ray disk (making up random numbers).  Sure the business wouldn't make as much money but I feel that quality is more important then a few extra dollars.  Would it be cheaper to get a chip that holds 35gb compare to a small sd card?  I'd rather have a cart that is around 4x3 inches instead of a simple sd card anyways.  With older carts, they had memory built onto it.  I don't know electronics that well but is it possible to use the console memory to get the data rather then having the cart memory be the main source?  Smaller memory chips or none at all would help cut the cost down as well.
Thanks in advance for your help image
  • kidiccurus
    0 kidiccurus over 12 years ago
    What games are your console going to playing? Depending on the games I can gage what size you will need. Chances are, 32gb is a little more than you need.
    0 e14 Contributor over 12 years ago in reply to kidiccurus
    Anything from retro, to kid friendly, to the more hardcore stuff.  After doing research, I've learned about SSD (Solid state drive).  They are much more affordable then sd cards and the perfect size to put in a 3x4 inch casing image
    Are you looking into making video games?
  • kidiccurus
    0 kidiccurus over 12 years ago in reply to e14 Contributor
    Not particularly. I'm considering it but I am more interested in the hardware. Are the games 2d or 3d? What processor are you using? What existing console do your games most closely match?
    I would like to have both 2d and 3d.  You don't need good graphics to make a solid fun game, however there is nothing wrong with impressive graphics along with a solid fun game as well image I don't have specific hardware details just yet.  Still writing down the idea of it to get patented, working on making 3d pictures/models, then I'll speak to investors and hardware companies to see what I can work with.  Ideally I'd like something between ps4 and wii u specs.
  • kidiccurus
    For those specs, disks are the most cost effective option by a long way. Cartridges are only suitable for low spec, low volume runs as they cost significantly more and hold less data. What I recommend is putting the disk inside a cartridge and then inserting the whole lot into the console. The console then interfaces with the disk while keeping it contained in the cartridge. This (in my opinion) combines the best of both worlds. A similar system way used for the 64DD (google it). If you prefer you could have games downloaded from the internet rather than use physical media. I agree that graphics are not  important. Sadly most gamers don't. When I first posted, I thought this was just a hobby project for games like pong. I was wrong. If you continue with this project, could you please send me the occasional update.
  • royston02
    0 royston02 over 12 years ago
    Check out Sir Ben's retro computer. You can use the cardtriges and use games instead of IO
    You can buy a ssd that holds much more data then a Blu-ray disk and loading times is instant with them so they are actually better and more durable then a disk.  I got excited when I did research about it image  The only thing I'm concerned about is if people talks about not being able to play dvds or blu-rays.  Wii U doesn't play them either but due to fan base, people accepts it regardless.  With apps like Netflix, Youtube, and Hulu who needs to play dvds or blu-rays anyways? Not to mention it would save on the cost of making the console.  As far as digital vs physical, me personally I'm a physical copy kind of guy, but I would rather give people the option of either or.  Perhaps make the digital release cheaper then the physical on release date.
    With that said I got everything written down image I'm trying to make concept 3d printable art for the console and controller using the 123d design. I have the image of it on my mind and some drawings down but I'm not so good with 3d art, even as user friendly 123d design is lol I will be happy to keep you updated image
  • kidiccurus
    Ssd's are very nice (The computer I'm using now has one). The problem is they cost a huge amount. The cart vs. disk war has already been fought and PlayStation beat n64 (unfortunately). Gamers chose a slow load over an expensive game. I like the idea but it isn't going to work unless the customers are millionaires.
