element14's The Ben Heck Show
Forum icade plus old android tablet equals quick arcade project?
  • Subscribers 30 subscribers
  • Views 1100 views
  • android
  • mame
  • icade
  • arcade
Hi Ben et al!
Thank you for the very practical and informative videos, particularly the Getting Started With Beaglebone Black video that really helped me figure something out about the set-up process that had eluded me.  Anyway, since you have done so many custom builds, I thought you'd be a good resource for my current project.
My name is Byron and I am an active maker who spends a lot of time at my local community workshop/hacker space, Fresno Ideaworks.  I had been thinking about making an arcade cabinet to set up at the shop after seeing a great kit for raspberry pi mini arcade at Maker Faire Bay Area.  Anyway, before that went anywhere I came across an old iCade at my local thrift store.  I bought it just for the buttons and joystick and case.  Then I realized that it was a Bluetooth keyboard and should be able to work with an old Lenovo K1 (Android) tablet I had lying around that happened to be the right size.  Well, after a little bit of legwork I was able to get them working together nicely and all the guys at the shop had fun yesterday playing Donkey Kong.
Great!  No need to reinvent the wheel, I can probably use what I already have and not even worry about a Pi in this equation.  I plan to build a new, slightly larger cabinet out of plywood that will securely house the iCade controller circuit, tablet and a small sound system, all powered by one ATX power supply. So far so good, I know what I am doing up to this point but here's the catch.  I would like to turn this into a semi-permanent cabinet that can simply be turned on and played by anyone at the shop.  Also, I would like to add a game I will design and have different games default or cycle through each time the system starts so that sooner or later, someone will play my game along with a handful of early 80s games that people already know.
So, is there a straightforward way to program the Android tablet to boot into Mame4Droid so that everything is ready to go?  Are we talking some kind of shell scripting here? And secondly, if I want to program an old 8-bit style game, in this case the kind of cheap knock-off copycat we used to see in the arcades (mine will be called 'Cuber' if that rings a bell, or knocks on a cabinet...) do you have any advice about what language/parameters I should use and how to compile it into a rom that my emulator can handle?
Any thoughts? Thank you and keep up the good work.
Byron
  • jds123
    0 jds123 over 11 years ago
    Would you be looking for something like this? https://play.google.com/store/apps/details?id=com.autostart&hl=en
    0 e14 Contributor over 11 years ago in reply to jds123
    That is exactly the kind of thing I was looking for!  This project just gets easier and easier.  BTW, did I say ATX power supply?
    How silly of me!  I should have said, power strip because I actually have wall warts for all of these things.
    For sound, some surround sound speakers and a pocket guitar amp should do the trick.
    Now to start building!  Perhaps the MAME forums can help me find out how to compile my program into a rom...
