element14's The Ben Heck Show
Forum Human energy
  • Replies 7 replies
  • Subscribers 31 subscribers
  • Views 1032 views
Human energy
royston02
royston02 over 12 years ago
This idea was in me for a long time. I know that when stepper motors are rotated, they generate electricity. However they are big and bulky. Which is the smallest thing that generates electricity in oscillatory motion(like stepper motors)?
Minimum amperage - 100-125ma.  Minimum voltage - 5V or high(AC/DC).
  • kidiccurus
    0 kidiccurus over 12 years ago
    Probably either piezoelectric crystals or just a DC motor.
  • vsluiter
    0 vsluiter over 12 years ago
    You're looking for 0.5W, and your title suggests that you want a human to make this.
    Piezo's won't work because they will never produce 0.5W continuously. I guess you'd be looking into small DC-motors, preferrably with a gearbox so you can move the slow speed of humans to a high rpm for the motor (generating a higher voltage). It's how these work: Bresser Junior Dynamo Torch: Amazon.co.uk: Electronics .
  • royston02
    0 royston02 over 12 years ago in reply to vsluiter
    By human energy, I meant that while walking, your legs move in pendulum motion, to and fro, so when it moves, attach something that could oscillatory motion and generate electricity. The medium which generates electricity is at the knee joint. Two things will be attached one to the thigh and one below knee. So while walking, the thigh portion remains stagnant and the bellow knee portion will move turning the medium and generating electricity.
  • kidiccurus
    0 kidiccurus over 12 years ago in reply to royston02
    Ben heck actually tried this in one of his episodes, simply by attaching the handle of one of these torches to a piece of wood and then someone's leg. I can't remember how affective it was, but I think he was able to charge a smartphone.
  • vsluiter
    0 vsluiter over 12 years ago in reply to royston02
    Nice idea. One of the issues you'll run into is that we, humans, are very easily getting irritated by objects that downgrade our own efficiency. We're very used at how our limbs work, and dampening our oscillating legs by draining energy is something that won't go unnoticed during walking. If you'd be able to brand it as 'exercising equipment' you might have a chance....
  • royston02
    Any practical answers, how can I use it to charge phones, which motors to use or gearbox's gear ratio or any direct motor which can generate 5V without much effort?
  • vsluiter
    You can do an inverse calculation: if you know the speed at which the knee will be travelling, you can make an estimate at the amount of power you'll want to drain, and then you can try to find a motor that does that power (0.5W?) at 5V+ DC, at that speed. Pololu sells a nice range of motors (25D and 37D series) that already have gearboxes. Because you'll probably need to do something for slightly lower speeds too, you'd better use a power converter to try to get maximum power. You can take a look at the Energy Harvesting Solutions group, where a few converters from Linear were used in combination with Wurth coils.
