element14's The Ben Heck Show
Forum Is it right? Laser Driver
  • Replies 11 replies
  • Subscribers 31 subscribers
  • Views 1522 views
david98xp
david98xp over 11 years ago
I'm building a laser driver for a dvd laser burner. I needs 200-250 mA and 1.8-2.2V.
Is it the right setup? Is the trimpot setup correct? The multimetre shows6.43V and the trimpot doesn't seem to change anything.
    jw0752 over 11 years ago +1
    Hi Guys, I didn't like the way the pin out was labeled in my ST Data Sheet so I looked up an ON Data sheet that clarifies things. Here is a link to the ON LM317T data sheet: http://datasheet.octopart.com…
    0 jw0752 over 11 years ago
    Hi Guys, Pins on pots, resistors, and capacitors are usually not numbered. This may be creating some confusion as to whether you are talking about the pot or the LM317. If you use the schematic from the data sheet you will have to tie the center of the pot to one side and ground it and run the other side of the pot to the #1 pin of the LM317 which is the adjust. If you pick one way to connect the center of the pot to the end you will increase resistance as you turn counter clock wise and if you connect the center to the other side of the pot instead you will increase resistance as you turn clock wise.
