element14's The Ben Heck Show
Forum Power circuit for Portable Pi
  • Subscribers 30 subscribers
  • Views 844 views
I am building a hand held portable raspberry pi. I have just plugging the battery in and using the thing, but I want to make the battery completely part of the unit without the need to unplug it when I am done. so here is what I want to do completely:
1. Have a switch to be the master on/off switch.
2. when the unit is plugged in to a dc power source (wall wart), you will have a switch that will let you to select between powering the unit or charge the unit
3 .Have led indicators for charging, unit powered by battery, unit powered by external
I already have the Pi working with a 7.4v battery for the last month. It is using a switching regulator that works til about 6.0v which is pretty much dead for the battery. The battery already has a built in charging PCB so all I have to do is apply at least 7.5 volts and it will charge with no issues.
below is a draft for the power circuit. Logically, here is how I think it should work:
Plugged In   Master On/Off   Charging/Wall power    Status
Yes          On              Charging               Charging
No           On              Charging               Battery Powered
Yes          Off             Charging               Charging
No           Off             Charging               Off - Does Nothing
Yes          On              Wall Power             Wall Powered
No           On              Wall Power             Battery Powered
Yes          Off             Wall Power             Off - Does Nothing
No           Off             Wall Power             Off - Does Nothing
Here is the circuit how I have it laid out right now in fritzing:
So my questions are:
a. will this work as I expect it
b. How do I add in the indicator led's
  • clem57
    0 clem57 over 11 years ago
    Looks like red charging on(left) and master switch on shorts the circuit which is bad! Build a table of the 4 possibilities and see where the electrons flow...
    0 e14 Contributor over 11 years ago in reply to clem57
    What should my circuit look like...I am still new to all of this
    I do have a charging board...i think it is only a 5v charging unit...Here is the link
    http://www.amazon.com/Lithium-Battery-Charging-Charger-Module/dp/B00AUDQWXQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1427313134&sr=1-1&keywords=rd084dy002
    I might have to have a separate jar just charging maybe
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    The master on/off switch should be on the regulated out side not the power jack.
