element14's The Ben Heck Show
Forum Rechargable battery circuit
  • Subscribers 30 subscribers
  • Views 574 views
  • battery
  • charger
rickseiden
rickseiden over 11 years ago
Back in 10/14 Ben did an episode on a rechargeable battery circuit.  I have a few questions about that circuit I was hoping someone could answer for me.
1) Would the same circuit work with 7.4v instead of 3.7?  I think you just have to change one resistor, but I'm not sure.  Oh, and you'd have to charge it off something other than USB, obviously.  I'm sure the datasheet has the how-to of it, so I'm just wondering if it would work or not.
2) Can you leave the battery hooked up to the circuit after charging is done, and use it to power another circuit, or would you have to disconnect the battery from there, and reconnect it to your "target" circuit?
3) Is there a through hole alternative?
What makes me ask these questions:  I have a circuit I'm building that will require a rechargeable battery.  I want to put the whole thing in a project box and seal it up, so the battery needs to be hooked up to both the charger circuit and the circuit I'm planning on running with it.
Thanks in advance!
Rick
  • elman128
    0 elman128 over 11 years ago
    This is a single-cell charging-only circuit, not full battery protection, so you will need at least over discharge protection too.
    Also, if you need two cell (7.4V) then you need completely different solution. This is not about voltage value only, you should monitor each cell voltage separately.
  • rickseiden
    0 rickseiden over 11 years ago in reply to elman128
    I'm having trouble finding example circuits and resources for this kind of thing.  Anything you can point out would be very helpful.
    Rick
  • elman128
    0 elman128 over 11 years ago in reply to rickseiden
    TI has wide choice of battery management chips. Look at them here Battery Chargers-Front-End Solutions | Products | Battery Management IC | Battery Charger IC
