element14's The Ben Heck Show
Forum Help with ASCII keyboard
  • Subscribers 30 subscribers
  • Views 596 views
gabyhass
gabyhass over 11 years ago
I was wondering what i would need to make a keyboard output standard ASCII text,and also what I would need to interpret the text,also what would I need to drive a small LCD,the reason for this is I wanted to make a small pocket computer like ben hecks BASIC computer plus the texting radios
     -thanks!,Gabriel wells
  • clem57
    0 clem57 over 11 years ago
    A Johnson counter to scan the input lines for a key press to cut down the number of input lines. LCD to display text. 30 push buttons. MCU to process the input into output.
    Clem
  • gabyhass
    0 gabyhass over 11 years ago in reply to clem57
    I was wondering how I would do that though I know what a johnson counter is but dont know how to wire it correctly so it can scan and then send data to get interpreted by the microcontroller
  • clem57
    0 clem57 over 11 years ago in reply to gabyhass
    Build a array of 10 outputs taking one at a time high. 3 rows are detectors (inputs) to sense which is high. See diagram:
                   0     1     2     3     4     5     6     7     8     9
    Row1     q     w      e     r     t      y     u     i      o     p
    Row2     a     s      d     f     g     h      j     k     l      sp
    Row3     z     x      c     v     b     n     m     ?    /      .
    So if Row2 detects when 3 is high, f was pressed. If Row1 detects when 9 is high, p was pressed.
    Clem
