element14's The Ben Heck Show
Forum Water Tight connector for a compact florescent
  • Subscribers 29 subscribers
  • Views 379 views
  • watertight_box
  • watertight
  • connector
mjames2005@comcast.net
mjames2005@comcast.net over 10 years ago
Hi all,
Im adding a 40w UV sterilizer to my pond and the one I ordered came with an external ballast.  I intend to put the put the ballast in a water tight enclosure and would like to have  connector on the outside to I can disconnect it in the winter.  The cable that runs from the ballast to the lamp is 4 conductor and the rubber jacket says 300v. Can anyone recommend a connector that would fit this application.  I was thinking of using a M12 but was not sure if that would work.
    jw0752 over 10 years ago
    Hi Mike,
    I would check with an electrician that does underwater lights for pools or fountains. It is unlikely that anyone on the forum will take a chance on making a recommendation for an application like this with potential electrical hazard. Good luck in your search.
