element14's The Ben Heck Show
Forum Build Idea: Raspberry Pi UPS(uninterruptible power supply)
  • Subscribers 29 subscribers
  • Views 666 views
erhan9049
erhan9049 over 9 years ago
I want to run a web server on my pi but I'm worried about power outages.
I want to see Ben and Felix build a UPS for the pi. Being able to use 18650 li-ion batteries would be awesome but a supercapacitor solution is fine too as long as it can give the pi enough time to power down properly.
    e14 Contributor over 9 years ago +2
    That sounds a great idea for a project although there are some relatively good and cheap off the shelf solutions that would do the job. I often use a USB powerbank to power my Raspberry Pi, all you need…
    e14 Contributor over 9 years ago in reply to erhan9049 +1
    I also think an episode on power management in general and a look at a common easy to use battery charging ic with pass through features would make for a good watch
    I often use a USB powerbank to power my Raspberry Pi, all you need is one that is capable of charging and discharging at the same time. Some powerbanks are great for this and others don't support it, look at this Reddit post for more information, there's some links at the bottom of it for powerbanks that do support this ability https://www.reddit.com/r/raspberry_pi/comments/3hm00e/usb_battery_packs_that_can_chargedischarge_at_the/
  • erhan9049
    erhan9049 over 9 years ago in reply to e14 Contributor
    Cool. I'll look into these. The off the shelf solutions look nice but I would like to use it with other kinds of SBCs too and some of it may not fit easily to some odd shaped SBCs.
    The power banks I have couldn't do it. I'll search for a cheap one that can.
    I still want to see them build one that can be built for cheap and can be used with all kinds of SBCs easily.
    I also think an episode on power management in general and a look at a common easy to use battery charging ic with pass through features would make for a good watch image
