Hack Like Heck
  • Hack Like Heck
Hack Like Heck
Blog David's HLH Build Part 1
Join Hack Like Heck to participate - click to join for free!
  • Author Author: a531016
  • Date Created: 23 Mar 2018 10:37 PM Date Created
  • Views 1577 views
  • hlh
  • davids hlh blog
a531016
a531016
23 Mar 2018
I now have the major components for the build, so it is time to go start looking at how all the bits could go together and fit to create the compact and truly portable device I want to create.
I know that the spacial fit for the battery is a top consideration, that will decide for me if I need to print a custom back for the controller, or if I can fit the bits in as is. Ideally, I would like the latter.
Perhaps more pressing is a decision on screen. My first instinct was to use a phone as a screen, and this adds to the compact, portable nature of the build that I was aiming for, but also reduces strain on the battery I will use for the main build. I have also obtained a 480X340 screen which can be driven by GPIO (sound familiar?). This would allow the device to be self-contained, even if it compromises on battery and physical size. Here are the 2 options placed together:
Looks good, reduces battery strain, buy is really cheating:
Will be harder to work with, but makes a nice self-contained unit.
The size of each seems appropriate, both compact enough, but large enough.
I think that Using a phone as a screen is, well cheating. If I took this route, I may as well use the phone hardware, and just attach the controller using an OTG adapter and be done with it! Which as a side note, maybe a fun project in itself! What are your thoughts?
So I think the next stage it to crack open the soldering kit and breadboard the key components, and make sure that they can work together. You can all look forward to a video or time-lapse of my bad soldering technique in the final product!
    genebren over 8 years ago +1
    I like the bigger screen. I think using the phone might be taking a lot of the fun (hacking) out of the project. You might want to stick a little closer to the BOM. Gene
  • a531016
    a531016 over 8 years ago in reply to binaryben +1
    Although I considered the phone, I think I had dismissed it fairly early on. I certainly would have started without waiting for the screen to be delivered! I hope mine isn't so big it becomes the SN35…
    Gene
    Gene
  • a531016
    a531016 over 8 years ago in reply to genebren
    I am going with the 3.5" screen, my biggest question is about how much performance I can squeeze out of it!
    You are quite right, I think the project would have been a little "sterile" if I have taken the compute route.
