Hack Like Heck
  • Hack Like Heck
Hack Like Heck
Blog David's HLH Build Part 2
Join Hack Like Heck to participate - click to join for free!
  • Author Author: a531016
  • Date Created: 25 Mar 2018 8:29 PM Date Created
  • Views 1557 views
  • hlh
  • davids hlh blog
a531016
a531016
25 Mar 2018
I am having a few bad days at this!
I started with the ribbon cable, only to find that it is solid core (which will break in my design in no time). So I deciding that I needed a stranded cable, which I had to get hold of today.
In the meantime, I did a few tests with the screen and a RPI model B+, to see what performance I could get from it. At least once I have this all connected and working, I have a fighting chance of getting the software right first time!
The good news was having found the pinout for the screen, it confirmed that only 16 connections were required, not the full 26 of the existing header connection. This will save space on the wiring in the device, reduce points of failure, and save me soldering. I started soldering the wiring to the RPI GPIO, and started work on desoldering the header on the screen. This required gently separating the screen and touch layer from the controller PCB.
This all went reasonably well, however at that point, my soldering iron died. I suppose that's my fault for putting on my Christmas list an not specifying a model myself! Either way, a new one has been ordered for collection tomorrow.
  • mayermakes
    mayermakes over 8 years ago +1
    Be carefull with the screen, I broke 2 of them earlier this year while attempting to flatten, them the ribbon cable is very delicate.
  • a531016
    a531016 over 8 years ago in reply to mayermakes +1
    I'll be honest, I was very anxious about it! The only reassurance I have is that I can get one next day delivery if it all goes wrong! How did your project end up? Was it a success?
  • mayermakes
    mayermakes over 8 years ago in reply to a531016 +1
    Yes I eventually was carefull enough to flatten it out propperly, but in the final conclusion of the build I realised it was not a neede step to accomplish the build, thickness was added back again by…
  • mayermakes
  • a531016
  • mayermakes
    Yes I eventually was carefull enough to flatten it out propperly, but in the final conclusion of the build I realised it was not a neede step to accomplish the build, thickness was added back again by the battery.
    If I would rebuild it (which was my original plan for hack like heck) i would place the battery inbetween the screen and RPI.
    the old unit achieved only the same form factor as if I would have left the screen intact.
    my HLH project is a totally different beast, i tried to use this kid of screen for it but switched to a very different one early on.
  • mayermakes
