Community Feedback
  • Community Feedback
Community Feedback
Forum Where do you get your spools of build wire?
Join Community Feedback to participate - click to join for free!
  • Answers 4 answers
  • Subscribers 9 subscribers
  • Views 1413 views
crazyonej
crazyonej over 9 years ago
I saw the spools of twisted pair wire in your shop.  I have been looking for some, where do you get it?
  • makerkaren
    makerkaren over 9 years ago +3 suggested
    What @rachaelp said. We don't actually keep spools of twisted wire lying around. We grab the gauge, quantity, and length we need for a project and stick the ends in a drill.
  • rachaelp
    rachaelp over 9 years ago +1 suggested
    Hi Jason, If you have other spools of wire to hand anyway you can easily make a length of twisted pair wire if you have a vice and a hand drill (manual or electric). The procedure is as follows: Cut two…
  • clem57
    clem57 over 9 years ago +1 suggested
    You do not say gauge or usage that varies on application, but one sample (not an endorsement here) is 20 Gauge Twisted Wire 100 ft. Spool. $24.99 (Save $5.00) . I suggest you qualify what you need and…
  • rachaelp
    0 rachaelp over 9 years ago
    Hi Jason,
    • Cut two identical lengths of the wires you plan to use about 50% or so longer than the length of twisted pair you will need.
    • Hold one end of each wire together and line them up before clamping them in the vice.
    • Pull the cables together gently at the other end and ensure that these line up and then insert these into the chuck of your drill.
    • Now turn the drill to twist the cables together ensuring you keep some tension on the wires so they don't form loops and get tangled.
    • Keep going until you have nicely formed twists evenly along the entire length of the pair.
    • The overall length will reduce as the twists form so keep an eye on this as you go.
    This is easiest with an electric hand drill but doesn't take too much longer even with a manual hand drill.
    Best Regards,
    Rachael
  • clem57
    0 clem57 over 9 years ago
    You do not say gauge or usage that varies on application, but one sample (not an endorsement here) is 20 Gauge Twisted Wire 100 ft. Spool. $24.99 (Save $5.00) . I suggest you qualify what you need and google it.
    What to look for :
    • Gauge of wire which affects the resistance and voltage
    • Plenum for fire prevention
    • Shielding or not shielding affects signal lose.
    • Number of pairs
    • and more
    Look at for guides http://www.conwire.com/multi-pair-cable/ , but shop around.
  • makerkaren
    0 makerkaren over 9 years ago
  • crazyonej
    0 crazyonej over 9 years ago in reply to rachaelp
    Thanks,  I will go ahead and do that then.
  • clem57
    0 clem57 over 9 years ago in reply to crazyonej
    Please blog about the way and the results. Could help others like me?
  • D_Hersey
    0 D_Hersey over 9 years ago
    Only bifilar and trifilar twists have the physical relationships equal.  A square wind would have some wires more distant than others
