DC to Daylight
  • DC to Daylight
DC to Daylight
Documents How to Build a Linear Variable Differential Transformer Motion Sensor and Detector -- DC to Daylight 29
Join DC to Daylight to participate - click to join for free!
  • Date Created: 11 Jul 2023 1:03 PM Date Created
  • Last Updated Last Updated: 15 Jun 2023 7:24 AM
  • Views 30981 views
  • Comments 6 comments
In this application-based episode, Derek shows how to build a sensor which measures linear motion using mutual inductance. He shows how an LVDT or linear variable displacement transducer works and how it is wound around an air-core. He also designs a differential detector circuit using a precision op-amp. He also provides two LTspice simulations, which show the drawbacks of using a simple diode vs. a precision rectifier so you can try it out on your own.
Watch the Video:
Bonus Content:
  • LTspice File
element14 presents
element14 presents  | About Derek  |  DC to Daylight
  • lvdt
  • mutual inductance
  • lock-in amplifier
  • preconditioner
  • precision rectifier lvdt detector circuit
  • linear variable differential transformer
  • AJM
    AJM over 1 year ago
    I am a Engineering Student
    I have to make LVDT project kit
    can you guide me?
    dougw over 3 years ago in reply to e14 Contributor
    We used RVDTs to measure angular position very accurately, very linearly and with fast response.
    e14 Contributor over 3 years ago in reply to dougw
    It really was easy to do with some random stuff I had on hand. Now that I've looked into RVDT's, that would be something interesting to play around with. I think optical encoders are probably more applicable to rotation / count applications.. as I think RVDTs are limited to +- 40 degrees and you'd have to have some kind of comparator/logic to detect a rotation event.
    e14 Contributor over 3 years ago in reply to DAB
    I had the idea to physically connect it to my truck's engine and show the FFT plot at different RPM's, but would have made the video too long. I think it would be a fun video to have a "sensors episode" where I show this application as one of the items.
    I haven't used LVDTs for hobby projects but have used both LVDTs and RVDTs in high accuracy position sensing applications at work. I might give it a try now that I have a spool of magnet wire.
    DAB over 3 years ago
    Very interesting episode.
    I have not used an LVDT, but I can see its usefulness in a wide range of applications.
    Very cool.
