element14 presents
element14 presents
element14 presents Forum Repsberry pi Music Jukebox with coin selector
  • Episodes
  • Subscribers 141 subscribers
  • Views 2329 views
RaphaelCC
RaphaelCC over 3 years ago
With little to no education in electronic or IT, you can only imagine the struggle in finding information or a platform from which to launch an ideas, so for months now I have been going to and fro around the internet looking for how I can build such a Jukebox.
I stumbled onto your YouTube channel, the video about a repsberry music play with buttons.
So I let me ask for help with my idea
Basically a music Jukebox, using repsberry pi, a screen and coin selector.
Thank you in advance.
  • KalebTheMaker
    KalebTheMaker over 3 years ago +2
    Hi there, This looks like it will work, and it's got a tutorial on how to interface it with a raspberry pi! Adafruit Coin Box Along with my video, that should be able to get you well on your way…
  • robogary
    robogary over 3 years ago
    Shouldnt be a struggle to find resources for a raspberry Pi jukebox , alot of those projects documented
    https://projects.raspberrypi.org/en/pathways/raspberry-pi-beginners
    https://magpi.raspberrypi.com/books/projects-5
    instead of a pushbotton to play a mechaical switch from the coin box is used to trigger songs.
    the biggest challenge I expect is to find a mechanical coin selector for a reasonable price.
    I'd recommend to start just by building the raspberry Pi jukebox with pushbuttons
  • KalebTheMaker
    Hi there,
    Adafruit Coin Box
    Along with my video, that should be able to get you well on your way on your project. Good Luck!
    Here is a link to that video.
    -KalebTheMaker
  • cstanton
    cstanton over 3 years ago in reply to KalebTheMaker
    KalebTheMaker said:
    Along with my video
    Got a link to that? Slight smile Which one was it again?
  • celcius1
    celcius1 over 3 years ago in reply to KalebTheMaker
    Good call, but one problem, you will need a voltage level converter on that, the output is 12v logic signal, so you could make a level converter using a transistor and a handful of resistors.
    james the bald engineer did a bit more of a deep dive on the use of coin mechs.
    x (x)
    x (x)
    x (x)
  • robogary
    robogary over 3 years ago in reply to celcius1
    https://wiki.dfrobot.com/2_Channel_Level_Converter_12V_to_3.3V_SKU_DFR0911
  • celcius1
    To interface coin mech's, note acceptors, and/or credit card terminals, needs a logic level converter. Here's the link to my GitHub github.com/.../RPi-Arcade-HAT for a prototype Arcade HAT I've been working on, take a closer note on the interface for bringing the signal from the coin mech to the Pi i have made a simple logic level converter using a transistor and appropriate resistors.  So that I can get the signal of the coin mech to be able to work with the Pi's 3.3v logic levels
    x (x)
    x (x)
    x (x)
