Project Videos
  • Project Videos
Project Videos
Documents Measuring Destructive Testing Force with a 20 Ton Hydraulic Press -- Episode 565
  • Date Created: 11 Aug 2022 5:00 PM Date Created
  • Last Updated Last Updated: 26 Aug 2022 7:24 AM
  • Views 497516 views
  • Comments 6 comments
The difference between fooling around and science is writing it down. And writing things it down is not really Clem's favorite thing to do. So he builds an Arduino powered digital readout for his 20 ton press to do it for him. It features a bright LCD display and an analog to digital converter to obtain the data from a load cell!
Supplemental Content:
  • Episode 565 Resources
Bill of Material:
Arduino Leonardo Arduino 1 Buy Now
"DFROBOT Weight Sensor Kit Dfrobot 1 Buy Now
"POWERPAX AC/DC Power Supply powerpax 1 Buy Now
"DFROBOT LCD Shield dfrobot 1 Buy Now
Additional Parts:
HX711 breakout
2t loadcell
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • digital
  • Destructive Testing
  • diy
  • Force Readout
  • Hydraulic Press
  • friday_release
  • e14p_CMM
  • mayermakes
    mayermakes over 4 years ago in reply to kostalba +1
    Due to vibrations the values can fluctuate. They way I do it is get an average measurement. Instead of just taking one measurement and displaying that, the Arduino takes many measurements (10-100) in a…
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    thanks!
    DAB over 4 years ago
    Nice build Clem.
  • mayermakes
    Instead of just taking one measurement and displaying that, the Arduino takes many measurements (10-100) in a set amount of time (use a for loop for that)
    than you add all the values and divide by the number of measurements taken. the time between individual measurements and displaying it can be varied to compensate for different amounts of vibration.
    in some cases its better to get a lot of values in a short time and sometimes just a few values over alonger period. its down to experimentation.
    In my case I do the compensation with the mentioned method above and also round to full kg since any smaller units it would be meaningless to my experiments.
    So all sub 1kg fluctuations are not displayed.
    for your 100kg range load cell you can cut of anything below 0,1kg for example.
  • kostalba
    kostalba over 4 years ago
    Awesome project!
    I have a question though. I made a similar project with Arduino and a load cell ( 1 to 100 kg ) but it seems the value I am getting is fluctuating between 2 values or sometimes ...many values. I am trying to make a digital scale so I want one, and only one, value. Any idea how can I correct this?
    Thank you in advance and keep up the good work!
  • mayermakes
    this is the more current library:
    github.com/.../u8g2
  • mayermakes
    little update : since I filmed the video I have learned that there is a successor library to u8glib named U8g2 that supports even more displays ! so you migth want to use the more modern one if you replicate this project.
