Project Videos
  • Project Videos
Project Videos
Documents How to Automate Industrial Welding Positioners with Arduino -- Episode 566
  • Date Created: 11 Aug 2022 5:03 PM Date Created
  • Last Updated Last Updated: 2 Sep 2022 7:24 AM
  • Views 467462 views
  • Comments 15 comments
In this episode we are looking at a couple of welding positioners that I worked on. Retrofitting one from an old lost PLC to arduino, and another built from scratch. Both of these devices are designed for use with a TIG welder. The rotary positioner puts the work where you need it, and the linear positioner holds the torch and moves it in a precise line to get perfect dimes!
Bill of Material:
Arduino UNO Arduino 2 Buy Now
Toggle Switch EATON 2 Buy Now
Rotary Encoder Bourns 1 Buy Now
Power Supply XP Power 2 Buy Now
Additional Parts:
3v Relay Module
8ch Optoisolator
NEMA 34 Stepper Motor
NEMA 32 Stepper Motor Driver
20x4 I2C LCD Display Module
Arduino UNO Screw Terminal Breakout Board
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • welding
  • diy
  • TIG
  • Welder
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to kmikemoo +1
    That is interesting, I did not know about that. I have some other projects that are going to be near TIG welders coming up, I will have to give this a shot. The interference was able to put enough voltage…
  • KalebTheMaker
    KalebTheMaker over 4 years ago +1
    One thing I forgot to mention in the video is how the system was grounded. I'll try to explain. When this shop was built, the guy that owns it built a steel mesh into the concrete with 3/4" threaded…
    DAB over 4 years ago
    Hi Kaleb,
    Did you try ferrite beads on the Arduino inputs?
    When I worked on putting devices on aircraft, we had a similar EMI issue, and the ferrite beads did wonders at attenuating the pulses.
    Hi Kaleb,
  • KalebTheMaker
    KalebTheMaker over 4 years ago in reply to DAB
    Hi DAB,
    Sorry, I replied to this yesterday but it didn't save...
    I did put ferrite beads on the multi-conductor wire from the pendant, but not on each individual conductor. Is that what you mean?
    -Kaleb
    DAB over 4 years ago in reply to KalebTheMaker
    Yes, you have to use them for every wire going into and out of the computer.
