      • Japan
      • Vietnam
Project Videos
  • Project Videos
Project Videos
Documents Synced NeoPixel Mickey Mouse Ears -- Episode 567
  • Date Created: 23 Aug 2022 8:35 PM Date Created
  • Last Updated Last Updated: 9 Sep 2022 7:24 AM
  • Views 191724 views
  • Likes 8 likes
  • Comments 19 comments
These light-up Mickey Ears show neopixel animations and sync with other ear hats for the ultimate Disney group attire! The sync is made possible with the Micro:bit’s internal radio to broadcast different animation modes. We designed animations to match the attractions across the park so we could really get into the theme of each ride. The templates and code for this project are available on the element14 community so you can make your own. See you at Disneyland!
Supplemental Content:
  • Episode 567 Resources
  • Win a Massive Raspberry Pi to Hang on Your Wall!
Bill of Material:
Single Board Computer, micro:bit V2 Board BBC MICRO:BIT 1 Buy Now
2 X AAA BATTERY HOLDER WITH ON/OFF SWITCH & JST PH CONNECTOR ADAFRUIT 1 Buy Now
Battery, 1.5 V, AAA, Alkaline, 1.1 Ah, Raised Positive and Flat Negative, 10.5 mm MULTICOMP PRO 2 Buy Now
Wire / Ribbon Cable 3M 1 Buy Now
Additional Parts:
Screws and Bolts
1/4 inch craft foam
Glitter Paper
A Black Baseball Hat
Hot Glue / Glue Gun
Straight Pins
element14 presents
element14 presents  |  About Natasha |  Project Videos
  • micro:bit
  • diy
  • disneyland
  • led
  • neopixel
  • Mickey Mouse
  • disney
  • e14p_NTC
  • friday_release
  • Workshopshed
    Workshopshed over 3 years ago
    Enjoyed this, a good build. I often dismiss the microbit as a low spec educational device. But it is actually quite capable.
    Did the batteries last all day?
  • TechnoChic
    TechnoChic over 3 years ago in reply to Workshopshed
    Totally! I'm always telling people to give micro:bit a chance - it's not just a kid's toy! Yes, the batteries lasted.... most of the day. We only turned the hats on when we were inside during the day and then once it got dark we kept them on. In the last few hours of the day only the red and green colors were visible as the batteries had begun to go. This would be easily remedied by using a lipo battery instead, but that's a more expensive item and requires a special charger. Maybe in V2!
  • TechnoChic
