Project Videos
  • Project Videos
Project Videos
Documents Making a WiFi Connected Audio Spectrum Analyzer with ESP32 -- Episode 570
  • Date Created: 8 Sep 2022 8:27 PM Date Created
  • Last Updated Last Updated: 30 Sep 2022 7:24 AM
  • Views 127836 views
  • Likes 10 likes
  • Comments 31 comments
This IoT/Web based Spectrum Analyzer uses a single ESP32 to create up to 64 channels to visualize the different audio bands.It uses only 6 external components to function .It has no LEDS or TFT screens but it uses a HTML webpage to display all the frequency bars. The ESP32 used is running on both processor cores. Core 1 is used to run the main loop of the program while core 0 is used to constantly update the webdata. Although the program itself makes it possible to run on a single core, using both cores will lead to better performance. This is so easy to build and program; you just have to try it! You won’t even have to install the ARDUINO software. Just use the web programmer to upload the precompiled binary file.
Supplemental Content:
  • Episode 570 Resources
  • Web Browser Programming:  https://donnersm.github.io/WebSpecElement/flash.html
  • ESP32 Repository: :  https://dl.espressif.com/dl/package_esp32_index.json
Layout Schematic
image image
Bill of Material:
Resistor Te Connectivity 4 Buy Now
Capacitor TDK 1 Buy Now
Switch Tactil Te Connectivity 1 Buy Now
Additional Parts:
ESP32 DOIT DEVKIT V1.0. You can use other ESP32 but you will have to adjust the wiring accordingly
A breadboard or experimantal PCB to build the circuit on.
element14 presents
element14 presents  |  About Mark Donners |  Project Videos
  • esp32
  • webserver
  • devkit
  • spectrum analyzer
  • DOIT
  • e14p_MD
  • Audio Visualizer
  • iot
  • friday_release
  • donnersm
    donnersm over 4 years ago in reply to kmikemoo +1
    And the best part, using the webprogrammer makes it so easy.
  • Rob_D
    Rob_D over 4 years ago
    What parts were used for the spectrum visualizer you are standing in front of?  Is there a build video for it?
  • antheliononline
    antheliononline over 4 years ago
    Is there a site for posted project source code and doc's ?
    Thanks,
  • donnersm
    donnersm over 4 years ago in reply to airscooter
    Make sure you use the right browser it only works with chrome or edge. Does it show a comport when you press program?
    • Vote Up -1 Vote Down
  • airscooter
    airscooter over 4 years ago
    Hi Mark,
    This was a great video and the result should be a helpful addition to my bench. Thank you for taking so much time with it.
    I am having a little difficulty getting the Web Programmer to Initialize. I have reset the board by holding the boot button and reset it by holding the boot button and touching the EN button. No joy here. So here I am all built and no where to go!!
    Help please,
    Dave L.
  • donnersm
    donnersm over 4 years ago in reply to DAB
    Thank you
    DAB over 4 years ago
    Very cool build.
  • donnersm
    donnersm over 4 years ago in reply to donnersm
    And easy to build!
  • donnersm
    donnersm over 4 years ago in reply to dougw
    Its a fun little project
    dougw over 4 years ago
    Great project. I will put ion my to-do list.
  • donnersm
