Project Videos
  • Project Videos
Project Videos
Documents How to Build a Spectrum Analyzer with Lego Bricks & Discrete Electronics -- Episode 599
  • Date Created: 12 Apr 2023 7:13 PM Date Created
  • Last Updated Last Updated: 21 Apr 2023 7:24 AM
  • Views 14844 views
  • Likes 11 likes
  • Comments 5 comments
In this project Mark demonstrates how to construct a spectrum analyzer using Lego bricks and discrete electronics. He provides building plans, schematics, and software source code to allow viewers to build their own versions. The device includes an analog front-end with bandpass filters, a preamplifier, an audio line input with a digital switch, a microcontroller, and a multiplexer for selecting different inputs.
Mark demonstrates the process of soldering the small components and assembles the board, which includes the ESP32 microcontroller and potentiometers for adjustment. He then shows how to put the board in the housing and add the necessary electronics, including LED strips and a microphone input, to complete the spectrum analyzer.
Watch the Video:
Bonus Content:
  • Download Code and Schematics!
  • B.O.M with Reference Design
Bill of Material:
ALPS ALPINE Rotary Potentiometer, 10 kohm, 1 Turns, Logarithmic, 50 mW, ± 20%, RK09K Series RK09D1130C2P 3 Buy Now
MULTICOMP PRO SMD Chip Resistor, 180 ohm, ± 1%, 250 mW, 0805 [2012 Metric], Thick Film, High Power 0805W8F1800T5E 1 Buy Now
MULTICOMP PRO SMD Chip Resistor, 2.7 kohm, ± 1%, 250 mW, 0805 [2012 Metric], Thick Film, High Power 0805W8F2701T5E 1 Buy Now
MULTICOMP PRO SMD Chip Resistor, 5.6 kohm, ± 1%, 250 mW, 0805 [2012 Metric], Thick Film, High Power 0805W8F5601T5E 2 Buy Now
MULTICOMP PRO Small Signal Diode, Single, 100 V, 150 mA, 2.5 V, 4 ns, 500 mA LL4148 10 Buy Now
TDK SMD Multilayer Ceramic Capacitor, 2.2 µF, 50 V, 0805 [2012 Metric], ± 10%, X7R, C Series 0805F225M500NT 2 Buy Now
PANASONIC CAP, ALU ELEC, AEC-Q200, 470UF, RAD CAN VZH471M1CTR-0810 4 Buy Now
MULTICOMP PRO SMD Multilayer Ceramic Capacitor, 33 pF, 50 V, 0805 [2012 Metric], ± 5%, C0G / NP0, MC Series CL21C330JBANNNC 1 Buy Now
OMRON SWITCH, SPNO, 0.05A, 24V, THT, 0.98N TC-1102-C-J-B 2 Buy Now
STMICROELECTRONICS Fast / Ultrafast Diode, 200 V, 4 A, Single, 1.05 V, 30 ns, 70 A ES5JB 2 Buy Now
MOLEX Wire-To-Board Connector, KK 5045 Series, Through Hole, Header, 2, 2.5 mm, Tin Plated Contacts RoHS Compliant: Yes 22041021 1 Buy Now
MOLEX Wire-To-Board Connector, Vertical, KK 5045 Series, Through Hole, Header, 3, 2.5 mm RoHS Compliant: Yes 22041031 1 Buy Now
MOLEX Wire-To-Board Connector, KK 5045 Series, Through Hole, Header, 4, 2.5 mm, Tin Plated Contacts RoHS Compliant: Yes 22041041 1 Buy Now
MULTICOMP PRO SMD Chip Resistor, 7.5 kohm, ± 0.1%, 100 mW, 0805 [2012 Metric], Thin Film, Precision 0805W8F7501T5E 1 Buy Now
SUSUMU SMD Chip Resistor, 200 ohm, ± 0.1%, 100 mW, 0805 [2012 Metric], Thin Film, Precision 0805W8F2000T5E 1 Buy Now
TEXAS INSTRUMENTS SWITCH, ANALOG 1-OHM SPDT, 5A3159 TS5A3159DBVR 1 Buy Now
NEXPERIA ANALOGUE MUX/DEMUX, 16:1, 180R, TSSOP-24 74HC4067PW,118 1 Buy Now
MULTICOMP PRO SMD Multilayer Ceramic Capacitor, 6800 pF, 50 V, 0805 [2012 Metric], ± 10%, X7R, MC Series 0805B682K500NT 2 Buy Now
MULTICOMP PRO SMD Multilayer Ceramic Capacitor, MC Series, 0.033 F, 10%, X7R, 50 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805B333K500NT 2 Buy Now
PANASONIC CAP, 22UF, 25VDC, ALU ELEC, HYBRID, SMD ROHS COMPLIANT: YES RVT1E220M0505 1 Buy Now
VISHAY RESISTOR, RCS0805 100 390R ET1 E3 ROHS COMPLIANT: YES RCS0805390RFKEA 2 Buy Now
MULTICOMP SMD Current Sense Resistors, MC Series, 24 kohm, 100 mW, - 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F2402T5E 1 Buy Now
MULTICOMP SMD Current Sense Resistors, MC Series, 33 kohm, 100 mW, - 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F3302T5E 1 Buy Now
MULTICOMP PRO SMD Current Sense Resistors, MC Series, 3.3 kohm, 100 mW, - 5%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F3301T5E 2 Buy Now
MULTICOMP PRO SMD Current Sense Resistors, MC Series, 560 ohm, 100 mW, - 5%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F5600T5E 1 Buy Now
BOURNS TRIMMER, 25 TURN 100K 3296W-1-104 1 Buy Now
BOURNS TRIMMER, 25 TURN 1M 3296W-1-105 1 Buy Now
BOURNS TRIMMER, 25 TURN 50K 3296W-1-503 1 Buy Now
STMICROELECTRONICS Operational Amplifier, Dual, 4 MHz, 2, 16 V/ s, 6V to 36V, SOIC, 8 RoHS Compliant: Yes TL082CDR 1 Buy Now
VISHAY Zener Single Diode, 3 V, 500 mW, SOD-123, 2 Pins, 150 °C, Surface Mount MMSZ4683 1 Buy Now
VISHAY CAP, 0.068µF, 50V, 10%, X7R, 0805 0805B683K500NT 4 Buy Now
BOURNS Trimpot, Multi Turn, Cermet, Top Adjust, 200 kohm, Through Hole, 25 Turns 3296W-1-204 1 Buy Now
YAGEO SMD Multilayer Ceramic Capacitor, 0.1 µF, 50 V, 0805 [2012 Metric], ± 10%, X7R, CC Series CC0805KRX7R9BB104 14 Buy Now
C46,C49,C50,C51,C52,C53" undefined undefined Buy Now
PHOENIX CONTACT Wire-To-Board Terminal Block, 5.08 mm, 2 Positions, 26 AWG, 14 AWG, 2.5 mm², Screw 1715721 2 Buy Now
PHOENIX CONTACT Wire-To-Board Terminal Block, 5.08 mm, 3 Positions, 26 AWG, 14 AWG, 2.5 mm², Screw 1715734 1 Buy Now
SAMSUNG ELECTRO-MECHANICS SMD Multilayer Ceramic Capacitor, 4.7 µF, 25 V, 0805 [2012 Metric], ± 10%, X5R, CL Series CL21A475KAQNNNE 10 Buy Now
SAMSUNG ELECTRO-MECHANICS SMD Multilayer Ceramic Capacitor, 10000 pF, 50 V, 0805 [2012 Metric], ± 10%, X7R, CL Series CL21B103KBANNNC 2 Buy Now
SAMSUNG ELECTRO-MECHANICS SMD Multilayer Ceramic Capacitor, 1 µF, 50 V, 0805 [2012 Metric], ± 10%, X7R, CL Series CL21B105KBFNNNE 4 Buy Now
SAMSUNG ELECTRO-MECHANICS SMD Multilayer Ceramic Capacitor, 0.22 µF, 50 V, 0805 [2012 Metric], ± 10%, X7R, CL Series CL21B224KBFNNNE 1 Buy Now
SAMSUNG ELECTRO-MECHANICS SMD Multilayer Ceramic Capacitor, 0.47 µF, 50 V, 0805 [2012 Metric], ± 10%, X7R, CL Series CL21B474KBFNNNE 4 Buy Now
KEMET Multilayer Ceramic Capacitor, AEC-Q200 MLCC Series, 2200 pF, - 5%, C0G / NP0, 50 V RoHS Compliant: Yes CL21C222JBFNNNE 2 Buy Now
MULTICOMP PRO SMD Chip Resistor, 10 kohm, ± 5%, 125 mW, 0805 [2012 Metric], Thick Film, Sulfur Resistant 0805W8F1002T5E 4 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 240 ohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F2400T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCMR Series, 2.4 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F2401T5E 1 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 3 kohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F3001T5E 1 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 30 kohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F3002T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCMR Series, 4.7 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F4701T5E 10 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 510 ohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F5100T5E 2 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 68 kohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F6802T5E 2 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 47 kohm, 125 mW, 5%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F4702T5E 4 Buy Now
MULTICOMP PRO Surface Mount Chip Resistor, Ceramic, MCMR Series, 75 kohm, 125 mW, 1%, 150 V, 0805 [2012 Metric] RoHS Compliant: Yes 0805W8F7502T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 220 ohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F2200T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 27 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F2702T5E 2 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 470 ohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F4700T5E 3 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 5.1 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F5101T5E 2 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 56 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F5602T5E 2 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 6.2 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F6201T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 62 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F6202T5E 1 Buy Now
MULTICOMP PRO Surface Mount Thick Film Resistor, MCSR 08 Series, 6.8 kohm, 125 mW, - 1%, 150 V RoHS Compliant: Yes 0805W8F6801T5E 2 Buy Now
STMICROELECTRONICS Operational Amplifier, QUAD, 4 MHz, 4, 16 V/ s, 6V to 36V, SOIC, 14 RoHS Compliant: Yes TL084CDR 3 Buy Now
MOLEX Pin Header, Wire-to-Board, 2.5 mm, 1 Rows, 7 Contacts, Through Hole Straight, KK 5045 Series 22041071 2 Buy Now
Additional Parts:
ESP32_DevKit_V1_DOIT
RegulatorLM1084S-5.0/TR
Fuse 5TR4A 250V
Lego bricks misc. See Lego BOM list
Or, order it here!
element14 presents
element14 presents  |  About Mark Donners |  Project Videos
  • LEGO
  • spectrum analyzer
  • diy
  • e14p_MD
  • Audio Visualizer
  • friday_release
  • donnersm
    donnersm over 3 years ago +2
    If you have questions, feel free to ask.
    DAB over 3 years ago
    Nice build, just what you need to bring some light to music.
  • donnersm
    donnersm over 3 years ago in reply to javagoza
    Ill check that out!
  • javagoza
    javagoza over 3 years ago
    Great build! I tried to do something similar but in digital using FFT and in mini format, with a small monochrome OLED display. I love your solution using Lego!
    Sound Spectrum Visualizer with Arduino Nano 33 BLE - Hackster.io
  • kmikemoo
    kmikemoo over 3 years ago
    Very cool!  I love the Lego case.  Awesome build. Thumbsup
  • donnersm
