Project Videos
  • Project Videos
Project Videos
Documents Charlieplexing Buttons and LEDs at the Same Time - How Hard Can It Be? -- Episode 604
  • Date Created: 10 May 2023 5:43 PM Date Created
  • Last Updated Last Updated: 26 May 2023 7:24 AM
  • Views 32181 views
  • Likes 9 likes
  • Comments 15 comments
So many buttons so little IO. When you want to drive a large number of LEDs or read buttons the obvious choice is multiplexing them. But there is a method called charlieplexing that lets you use even more LEDs and buttons with even less IO pins. Clem wants to interface a large amount of buttons and LEDs with a microcontroller but has a limited number of pins.   He's also trying to save money on parts. Could you just replace expensive signal diodes with cheap LEDs? Could you use the same pins to read buttons and drive LEDs in the same matrix? Could you also achieve true n-key rollover without having a diode on every single button? How hard can it be?
Watch the Video:
Bonus Content:
  • Login to Download the Code!
Bill of Material:
LED, Super Red, Through Hole, T-1 3/4 (5mm), 12 mA, 5 V, 640 nm Multicomp 9 Buy Now
Arduino Mega 2560, ATmega2560, 54 I/O, 256KB Flash, 8KB SRAM, 4KB EEPROM Arduino 1 Buy Now
Jumper Wire Kit, Multicolour, 2 mm - 125 mm, 22 AWG, 140 Piece Multicomp 1 Buy Now
Breadboard, Mounted, 1580 Pin, 10mm, x 135mm Multicomp 1 Buy Now
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • buttons
  • keyboard
  • multiplexing
  • leds
  • Charlieplexing
  • friday_release
  • arduino mega
  • e14p_CMM
    dougw over 3 years ago
    For LEDs I prefer latched decoders, not any kind of multiplexing. I am okay with serially addressable LEDs, especially when variable brightness is needed.
    For buttons, I an okay with 2D cross-point matrices, if I can't have a pin for each individually hardware-debounced switch.
  • charlieo21
    charlieo21 over 3 years ago in reply to mayermakes
    I like this one, LP5009, it is a 9-channel driver so you can connect 3 RGB LEDs.
    For a matrix LED configuration, I only had used this one LP5891.
  • mayermakes
    mayermakes over 3 years ago in reply to charlieo21
    Any particular Ic you like to use?
  • charlieo21
    I like the serial ICs with specific functions and protections for LED driving.
  • mayermakes
    So what is your favourite method of driving a lot of leds/buttons. Charlieplexing, Multiplexing, Serial ICs or something completelly different?
