Project Videos
  • Project Videos
Project Videos
Documents Arduino Automatic Wire Cutter and Stripper -- Episode 368
EMI-Reduction-Techniques
  • Date Created: 13 Nov 2018 9:32 PM Date Created
  • Last Updated Last Updated: 16 Nov 2018 8:24 AM
  • Views 13053 views
  • Likes 15 likes
  • Comments 60 comments
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
Say goodbye to cramped wrists and handheld gadgets for cutting wire and say hello to your new workhorse on the workbench: the A.W.C.S. The “Ox” is an automatic wire cutting and stripping machine meant to take some of the busywork out of building electronic gadgets. Will it succeed? Will it actually save time? Will my wrists be spared from carpal tunnel and tendonitis? Let’s find out!
Supplemental Content:
  • Project Code Download
#include <Adafruit_CharacterOLED.h>
#include <AccelStepper.h>
#include <Bounce2.h>
#include <Encoder.h>
#define ENCODER_DO_NOT_USE_INTERRUPTS
#define PIN_ENABLE_FEED 21
#define PIN_ENC_A 2
#define PIN_ENC_B 3
#define PIN_BUTTON_ENC 4
#define PIN_BUTTON_RED 5
#define PIN_LED 13
#define PIN_SENSOR A0
#define WIRE_QUANT_MIN 1
#define WIRE_QUANT_MAX 100
#define WIRE_MIN_LEN 5
#define WIRE_AWG 22
Adafruit_CharacterOLED lcd(OLED_V2, 6, 7, 8, 9, 10, 11, 12);
AccelStepper stepCut(1, 19, 18); // (DRIVER, STEP, DIR)
AccelStepper stepFeed(1, 15, 14);
Encoder encoder(PIN_ENC_A, PIN_ENC_B);
Bounce buttonOK = Bounce();
Bounce buttonRED = Bounce();
int curSpool = 0; // in future, give each spool a unique id and track total length cut
int curSpoolRemaining = 0;
int mainMode = 0;
int subMode = 0;
int lastSubMode = -99;
int scrollPos = 0;
int lastScrollPos = -99;
long encPos = -999;
long lastEncPos = 0;
long retractPos = -3600;
long stripPos = -1000; //
long stripFeedDistance = 0;
long lengthFeedDistance = 0;
long cutPos = 200;
long targetPos = 0;
boolean isHomed = false;
int bladeCycleState = 0;
int sensorVal = 0;
uint16_t wireQuantity = 0;
uint16_t wireLength = 0; // in milimeters
uint16_t wireStripLength = 0;
uint16_t wiresCut = 0;
float conductor_diam = 0.64516; // 22 AWG
float feed_diam = 22.0; // uncalibrated!
float feed_circum = PI * feed_diam; // 69.115mm per rev
//float feed_res = feed_circum / 200.0; // .346mm per step
float feed_res = 0.346;
// Z travel is 1/16" (1.5875mm) per revolution
// both motors are 1.8deg per step (200 per revolution)
// the cut motor driver has a noncofigurable default 10x microstepping rate
// so z resolution = 0.00079375mm per "full" step sent
// leaving us with ~1260 steps per mm z travel
boolean ledState = 0;
long curTime = 0;
long lastTime = 0;
int deltaTime = 100;
void setup(){
  Serial.begin(115200);
  lcd.begin(16, 2);
  lcd.print("AWCS READY!");
  stepCut.setPinsInverted(true, true);
  stepFeed.setPinsInverted(true, true);
  stepFeed.setMaxSpeed(2000);
  stepFeed.setAcceleration(6000);
  stepCut.setMaxSpeed(20000);
  stepCut.setAcceleration(40000);
  pinMode(PIN_ENABLE_FEED, OUTPUT);
  pinMode(PIN_BUTTON_ENC, INPUT_PULLUP);
  pinMode(PIN_BUTTON_RED, INPUT_PULLUP);
  pinMode(PIN_LED, OUTPUT);
  buttonOK.attach(PIN_BUTTON_ENC);
  buttonRED.attach(PIN_BUTTON_RED);
  buttonOK.interval(5);
  buttonRED.interval(5);
  digitalWrite(PIN_ENABLE_FEED, LOW);
  delay(200);
  digitalWrite(PIN_ENABLE_FEED, HIGH);
  delay(200);
  //setZHOME():
  setBlade('H');
  //lcd.clear();
  printMenu();
  printCursor(0);
  subMode = 5;
  setBlade('R');
void loop(){
  /*curTime = millis(); // VERY BASIC Calibration measurement
  if (curTime - lastTime > deltaTime){
    lastTime = curTime;
     getInput();
    //lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("POS:   ");
    lcd.setCursor(4, 0);
    lcd.print(scrollPos);
    lcd.setCursor(0, 1);
    lcd.print("SEN:    ");
    lcd.setCursor(4, 1);
    lcd.print(sensorVal);
    cutPos = 63 * scrollPos;
    stepCut.moveTo(cutPos);
  stepCut.run();*/
  getInput();
  switch(mainMode){
    case 0: // MAIN MENU
        switch(subMode){
          case 0: // choose quantity
            if( scrollPos != lastScrollPos){
              if (scrollPos > 999)scrollPos = 1;
              if (scrollPos < 1)scrollPos = 999;
              lastScrollPos = scrollPos;
              wireQuantity = scrollPos;
              lcd.setCursor(5, 0);
              lcd.print("   "); // clear
              lcd.print(wireQuantity);
            if (buttonOK.fell())returnToMenu();
          break;
          case 1: // choose length (resolution of 5mm)
              if (scrollPos > 99)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 99;
              wireLength = scrollPos * 5;
              lcd.setCursor(13, 0);
              lcd.print(wireLength);
          break;
          case 2: // choose strip length (default strip both ends)
              if (scrollPos > 999)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 999;
              wireStripLength = scrollPos;
              lcd.setCursor(5, 1);
              lcd.print(wireStripLength);
          break;
          case 3: // run
              subMode = 5;
              mainMode = 1; // RUN!
              lcd.clear();
              lcd.home();
              lcd.print("NOW CUTTING:");
              printJobStatus();
              setBlade('R');
              stepFeed.setCurrentPosition(0);
              stripFeedDistance = 32* round(float(wireStripLength)/feed_res);
              lengthFeedDistance = 32* round((2.0*float(wireStripLength))/feed_res);
              Serial.print("FEED STEPS: ");Serial.println(stripFeedDistance);
              Serial.print("FEED DIST: ");Serial.println(lengthFeedDistance);
          break;
          case 4: // clear
            resetParameters();
            printMenu();
            returnToMenu();
          break;
          case 5: // scrolling
              if (scrollPos > 4)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 4;
              printCursor(scrollPos);
              if (buttonOK.fell()){
                subMode = scrollPos;
                //delay(200);
          break;
    break;
    case 1: // RUN
      // loop through quantity, allow mid-job canceling
      switch (bladeCycleState){
        case 0: // initial retract, then feed length of strip
          if (stepCut.distanceToGo() == 0){ // allow the blade to retract
            printJobStatus(); // show wire X of N wires
            bladeCycleState++;
            stepFeed.moveTo(stripFeedDistance); // feed length of strip
        break;
        case 1: // feed, then strip
          if (stepFeed.distanceToGo() == 0){ // allow strip length to fininsh feeding
            bladeCycleState++;
            setBlade('S');
        break;
        case 2: // strip, then retract
          if (stepCut.distanceToGo() == 0){ // allow time to strip
            bladeCycleState++;
            setBlade('R');
        break;
        case 3: // retract, then feed length of wire
          if (stepCut.distanceToGo() == 0){ // allow retraction
            bladeCycleState++;
            stepFeed.moveTo(lengthFeedDistance);
        break;
        case 4: // feed, then strip
          if (stepFeed.distanceToGo() == 0){ // allow feed movement etc.
            bladeCycleState++;
            setBlade('S');
        break;
        case 5: // strip, then retract
          if (stepCut.distanceToGo() == 0){ // allow feed movement etc.
            bladeCycleState++;
            setBlade('R');
        break;
         case 6: // retract, then feed
            bladeCycleState++;
        break;
        case 7: // retract, then feed
            bladeCycleState++;
            setBlade('C');
        break;
        case 8: // cut, then retract and loop if more wires need to run.
            wiresCut++;
            setBlade('R');
        break;
      // return to main menu when done or cancel the job
      if (buttonRED.fell() || wiresCut >= wireQuantity){
        mainMode = 0;
        resetParameters();
        subMode = 5;
        returnToMenu();
        printMenu();
        printCursor(0);
    break;
  // the motors only really move if there is a remaning position to travel,
  // and this needs to be called often enough that nesting it
  // inside some other function doesn't help much, so we'll just keep the .run() here
  stepFeed.run();
  stepCut.run();
} // END MAIN LOOP
void printJobStatus(){
   lcd.print("WIRE     OF   ");
   lcd.print(wiresCut+1);
   lcd.setCursor(11, 1);
void setBlade(char bladePos){
  switch (bladePos){
    case 'H': // home
      while (!isHomed){
        curTime = millis();
        if (curTime - lastTime > 100){
          lastTime = curTime;
          sensorVal = analogRead(PIN_SENSOR);
          if (sensorVal < 430){
            targetPos += 63;
            stepCut.moveTo(targetPos);
          } else {
            isHomed = true;
            stepCut.setCurrentPosition(0);
        stepCut.run();
    break;
    case 'R': // retract
      stepCut.moveTo(retractPos);
    break;
    case 'S': // strip
      stepCut.moveTo(stripPos);
    break;
    case 'C': // cut
    break;
void returnToMenu(){
  scrollPos = subMode;
  subMode = 5;
void printCursor(int cursorPos){
  //clear old cursor positions
  lcd.print(" ");
  lcd.setCursor(8, 0);
  lcd.print(" ");
  lcd.print(" ");
  lcd.setCursor(8, 1);
  lcd.print(" ");
  lcd.setCursor(12, 1);
  lcd.print(" ");
  switch(cursorPos){
    case 0:
      lcd.print(">");
    break;
    case 1:
      lcd.print(">");
    break;
    case 2:
      lcd.print(">");
    break;
    case 3:
      lcd.print(">");
    break;
    case 4:
      lcd.print(">");
    break;
void printMenu(){
  lcd.print(" QTY:    WRL:   ");
  lcd.print(" STL:    RUN CLR");
void resetParameters(){
  wireQuantity = 0;
  wireLength = 0;
  wiresCut = 0;
void getInput(){
  buttonOK.update();
  buttonRED.update();
    ledState = !ledState;
    digitalWrite(PIN_LED, ledState);
  encPos = encoder.read();
  if (abs(encPos - lastEncPos) > 4){ // did the encoder move one detent?
    if (encPos - lastEncPos > 0){ // positive
      scrollPos++;
    } else { // negative
      scrollPos--;
    lastEncPos = encPos;
Bill of Material:
Product Name Manufacturer Quantity
Buy Kit
Stepper Motor Bipolar 1 A Two Phase 3.4 ohm 6.5 mH
SANYO DENKI - SANMOTION 1 Buy Now
Stepper Motor Power Step High Torque Bipolar 294 in-oz 2.8 A Two Phase 1.1 ohm 3.8 mH
LIN ENGINEERING 1 Buy Now
TMCM-1070 -  Stepper Motor Driver, 2-Phase, Single Axis, 2.8A, 24V DC Output, USB, RS485, CAN TRINAMIC 1 Buy Now
Motor Driver R701 Microstepping Two Phase 12 to 80 Vdc 7 A 560 W 200 kHz LIN ENGINEERING 1 Buy Now
A100067 -  Development Board, Arduino Mega 2560 Rev3 RETAIL, ATmega2560 MCU, 54 3.3V I/O, 16 Analogue Inputs ARDUINO 1 Buy Now
1141 -  Assembled Data Logging Shield For Arduino ADAFRUIT 1 Buy Now
24-15112 -  Wire, PVC, Red, 22 AWG, 100 ft, 30.5 m STELLAR LABS 1 Buy Now
OLED Character Display ADAFRUIT 1 Buy Now
Pushbutton Switch Off(On SPST 125 V 50 V 400 mA Solder APEM 1 Buy Now
Incremental Encoder 5 VDC 2 Channels 60 rpm 24 Detents 24 Pulses PEC11R Series BOURNS 1 Buy Now
Hall Effect Proximity Sensor Flange Mount 55100 Series Analogue 4.5 to 5.5 Vdc HAMLIN 1 Buy Now
AC/DC Enclosed Power Supply(PSU ITE 1 Outputs 200 W 24 V 8.4 A TDK-LAMBDA 1 Buy Now
Additional Parts:
Product Name Quantity
SCHLEUNIGER CS 9100 “V” STYLE CUTTING AND STRIPPING BLADES
1
  • oled
  • stripper
  • automatic
  • arduino_vcp
  • manufacturing
  • vcp_arduino
  • friday_releasedj
  • wire cutter
  • adafruit
  • atmega2560
  • arduino_mega
  • automation
  • dj harrington
  • friday_release
  • e14presents_djharrigan
  • mrvolt
    mrvolt over 7 years ago in reply to juanecs +4
    Hi Juan, I can share those next week, but I want to warn you that the design needs a lot of improvement to be reliable and the bill of materials needs to be refined/simplified.
  • hutkikz
    hutkikz over 5 years ago +4
    I just thought you guys would like to see the machine I built inspired by DJ's excellent video!. www.youtube.com/watch I supersized it a bit and changed it up to use the parts and materials I had…
    dougw over 7 years ago in reply to DAB +3
    Have you tried a wire-wrap tool meant for stripping 30 gage Kynar? I actually end up using a low cost tool like this - with the stop adjusted properly:
    DAB over 7 years ago
    Interesting build, but I must say, for 22 gage wire I feel like you are using a sledge hammer to pound a one penny nail.
    Now, what I would like is something to help strip 30 gage wires. Those little suckers are small to see, impossible to hold and no stripper I have reliably does the job.
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to dougw
    Wire Wrap:
    I was first introduced to wire wrap about 6 years ago (I know it was the only way back in the day) when I started making the lights for R2D2's dome.  I bought the gizmo and a spool of super small wire, but for the life of me, I couldn't figure out how to make it happen more effiently than just soldering.
    Doug, can you give me the debrief on how/why to wire wrap?
    -Sean
    dougw over 7 years ago in reply to Sean_Miller
    Wire wrap sockets could have 4 wires on each pin. They allowed chips (in sockets) to be densely packed right up against each other and make arbitrary connections without spending time worrying about routing. A wire wrap circuit could be connected much faster than laying out a PCB and much more densely packed than any soldering solution. For prototyping, un-wrapping connections and wrapping different connections was easy and clean.
    The gas-tight wire wrap connections were just as reliable as soldering, lower impedance and some claimed even better strength than soldering. If you use an electric wire-wrap gun like the one I have, with a spool of wire on it, you can make connections almost as fast as you can pull the trigger, way, way faster than stripping and soldering. If you are connecting a net or multiple pins on the same bus, you don't even need to cut the wire at each pin, just daisy chain to the next pin. Even manual wrapping tools, like the one above, can be quick and efficient if you are properly set up with pre-cut, pre stripped wires of appropriate lengths. There are many tricks to efficient wire-wrapping.
    It has fallen out of favor these days mostly because surface mount parts don't go in sockets, density needs to be higher, especially in the vertical direction and signal frequencies can be too high for random wire routing. However there are still many applications where it is the best and most efficient way to make a connection. For example, when making a connection between 2 header pins on a PCB - those square pins are still compatible with wire wrap tools. The connection is far stronger, far lower impedance, and takes up far less space than using a wire jumper. And it is easy to remove a wire wrap if you need to - much easier than de-soldering.
    Wire-wrapping could be fully automated if you put your mind to it.
    I am very glad I still have all the tools and wire. They can provide a very convenient way to make reliable connections.
  • neilk
    neilk over 7 years ago in reply to dougw
    I still use a wire wrap using a hand tool like the one you showed. Both the tool and my stock of wire (pre-cut, different lengths and a spool) date back over 30 years.
    Neil
  • mrvolt
    mrvolt over 7 years ago in reply to DAB
    Absolutely. I wanted torque to spare so I could push this to thicker gauges, but stuck with 22 for the sake of the video and guaranteed "success."
  • blacksvtf03
    blacksvtf03 over 7 years ago in reply to mrvolt
    Can you build me one??
