      • Japan
      • Vietnam
Project Videos
  • Project Videos
Project Videos
Documents Arduino Automatic Wire Cutter and Stripper -- Episode 368
  • Date Created: 13 Nov 2018 9:32 PM Date Created
  • Last Updated Last Updated: 16 Nov 2018 8:24 AM
  • Views 12195 views
  • Likes 15 likes
  • Comments 59 comments
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
Say goodbye to cramped wrists and handheld gadgets for cutting wire and say hello to your new workhorse on the workbench: the A.W.C.S. The “Ox” is an automatic wire cutting and stripping machine meant to take some of the busywork out of building electronic gadgets. Will it succeed? Will it actually save time? Will my wrists be spared from carpal tunnel and tendonitis? Let’s find out!
Supplemental Content:
  • Project Code Download
#include <Adafruit_CharacterOLED.h>
#include <AccelStepper.h>
#include <Bounce2.h>
#include <Encoder.h>
#define ENCODER_DO_NOT_USE_INTERRUPTS
#define PIN_ENABLE_FEED 21
#define PIN_ENC_A 2
#define PIN_ENC_B 3
#define PIN_BUTTON_ENC 4
#define PIN_BUTTON_RED 5
#define PIN_LED 13
#define PIN_SENSOR A0
#define WIRE_QUANT_MIN 1
#define WIRE_QUANT_MAX 100
#define WIRE_MIN_LEN 5
#define WIRE_AWG 22
Adafruit_CharacterOLED lcd(OLED_V2, 6, 7, 8, 9, 10, 11, 12);
AccelStepper stepCut(1, 19, 18); // (DRIVER, STEP, DIR)
AccelStepper stepFeed(1, 15, 14);
Encoder encoder(PIN_ENC_A, PIN_ENC_B);
Bounce buttonOK = Bounce();
Bounce buttonRED = Bounce();
int curSpool = 0; // in future, give each spool a unique id and track total length cut
int curSpoolRemaining = 0;
int mainMode = 0;
int subMode = 0;
int lastSubMode = -99;
int scrollPos = 0;
int lastScrollPos = -99;
long encPos = -999;
long lastEncPos = 0;
long retractPos = -3600;
long stripPos = -1000; //
long stripFeedDistance = 0;
long lengthFeedDistance = 0;
long cutPos = 200;
long targetPos = 0;
boolean isHomed = false;
int bladeCycleState = 0;
int sensorVal = 0;
uint16_t wireQuantity = 0;
uint16_t wireLength = 0; // in milimeters
uint16_t wireStripLength = 0;
uint16_t wiresCut = 0;
float conductor_diam = 0.64516; // 22 AWG
float feed_diam = 22.0; // uncalibrated!
float feed_circum = PI * feed_diam; // 69.115mm per rev
//float feed_res = feed_circum / 200.0; // .346mm per step
float feed_res = 0.346;
// Z travel is 1/16" (1.5875mm) per revolution
// both motors are 1.8deg per step (200 per revolution)
// the cut motor driver has a noncofigurable default 10x microstepping rate
// so z resolution = 0.00079375mm per "full" step sent
// leaving us with ~1260 steps per mm z travel
boolean ledState = 0;
long curTime = 0;
long lastTime = 0;
int deltaTime = 100;
void setup(){
  Serial.begin(115200);
  lcd.begin(16, 2);
  lcd.print("AWCS READY!");
  stepCut.setPinsInverted(true, true);
  stepFeed.setPinsInverted(true, true);
  stepFeed.setMaxSpeed(2000);
  stepFeed.setAcceleration(6000);
  stepCut.setMaxSpeed(20000);
  stepCut.setAcceleration(40000);
  pinMode(PIN_ENABLE_FEED, OUTPUT);
  pinMode(PIN_BUTTON_ENC, INPUT_PULLUP);
  pinMode(PIN_BUTTON_RED, INPUT_PULLUP);
  pinMode(PIN_LED, OUTPUT);
  buttonOK.attach(PIN_BUTTON_ENC);
  buttonRED.attach(PIN_BUTTON_RED);
  buttonOK.interval(5);
  buttonRED.interval(5);
  digitalWrite(PIN_ENABLE_FEED, LOW);
  delay(200);
  digitalWrite(PIN_ENABLE_FEED, HIGH);
  delay(200);
  //setZHOME():
  setBlade('H');
  //lcd.clear();
  printMenu();
  printCursor(0);
  subMode = 5;
  setBlade('R');
void loop(){
  /*curTime = millis(); // VERY BASIC Calibration measurement
  if (curTime - lastTime > deltaTime){
    lastTime = curTime;
     getInput();
    //lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("POS:   ");
    lcd.setCursor(4, 0);
    lcd.print(scrollPos);
    lcd.setCursor(0, 1);
    lcd.print("SEN:    ");
    lcd.setCursor(4, 1);
    lcd.print(sensorVal);
    cutPos = 63 * scrollPos;
    stepCut.moveTo(cutPos);
  stepCut.run();*/
  getInput();
  switch(mainMode){
    case 0: // MAIN MENU
        switch(subMode){
          case 0: // choose quantity
            if( scrollPos != lastScrollPos){
              if (scrollPos > 999)scrollPos = 1;
              if (scrollPos < 1)scrollPos = 999;
              lastScrollPos = scrollPos;
              wireQuantity = scrollPos;
              lcd.setCursor(5, 0);
              lcd.print("   "); // clear
              lcd.print(wireQuantity);
            if (buttonOK.fell())returnToMenu();
          break;
          case 1: // choose length (resolution of 5mm)
              if (scrollPos > 99)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 99;
              wireLength = scrollPos * 5;
              lcd.setCursor(13, 0);
              lcd.print(wireLength);
          break;
          case 2: // choose strip length (default strip both ends)
              if (scrollPos > 999)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 999;
              wireStripLength = scrollPos;
              lcd.setCursor(5, 1);
              lcd.print(wireStripLength);
          break;
          case 3: // run
              subMode = 5;
              mainMode = 1; // RUN!
              lcd.clear();
              lcd.home();
              lcd.print("NOW CUTTING:");
              printJobStatus();
              setBlade('R');
              stepFeed.setCurrentPosition(0);
              stripFeedDistance = 32* round(float(wireStripLength)/feed_res);
              lengthFeedDistance = 32* round((2.0*float(wireStripLength))/feed_res);
              Serial.print("FEED STEPS: ");Serial.println(stripFeedDistance);
              Serial.print("FEED DIST: ");Serial.println(lengthFeedDistance);
          break;
          case 4: // clear
            resetParameters();
            printMenu();
            returnToMenu();
          break;
          case 5: // scrolling
              if (scrollPos > 4)scrollPos = 0;
              if (scrollPos < 0)scrollPos = 4;
              printCursor(scrollPos);
              if (buttonOK.fell()){
                subMode = scrollPos;
                //delay(200);
          break;
    break;
    case 1: // RUN
      // loop through quantity, allow mid-job canceling
      switch (bladeCycleState){
        case 0: // initial retract, then feed length of strip
          if (stepCut.distanceToGo() == 0){ // allow the blade to retract
            printJobStatus(); // show wire X of N wires
            bladeCycleState++;
            stepFeed.moveTo(stripFeedDistance); // feed length of strip
        break;
        case 1: // feed, then strip
          if (stepFeed.distanceToGo() == 0){ // allow strip length to fininsh feeding
            bladeCycleState++;
            setBlade('S');
        break;
        case 2: // strip, then retract
          if (stepCut.distanceToGo() == 0){ // allow time to strip
            bladeCycleState++;
            setBlade('R');
        break;
        case 3: // retract, then feed length of wire
          if (stepCut.distanceToGo() == 0){ // allow retraction
            bladeCycleState++;
            stepFeed.moveTo(lengthFeedDistance);
        break;
        case 4: // feed, then strip
          if (stepFeed.distanceToGo() == 0){ // allow feed movement etc.
            bladeCycleState++;
            setBlade('S');
        break;
        case 5: // strip, then retract
          if (stepCut.distanceToGo() == 0){ // allow feed movement etc.
            bladeCycleState++;
            setBlade('R');
        break;
         case 6: // retract, then feed
            bladeCycleState++;
        break;
        case 7: // retract, then feed
            bladeCycleState++;
            setBlade('C');
        break;
        case 8: // cut, then retract and loop if more wires need to run.
            wiresCut++;
            setBlade('R');
        break;
      // return to main menu when done or cancel the job
      if (buttonRED.fell() || wiresCut >= wireQuantity){
        mainMode = 0;
        resetParameters();
        subMode = 5;
        returnToMenu();
        printMenu();
        printCursor(0);
    break;
  // the motors only really move if there is a remaning position to travel,
  // and this needs to be called often enough that nesting it
  // inside some other function doesn't help much, so we'll just keep the .run() here
  stepFeed.run();
  stepCut.run();
} // END MAIN LOOP
void printJobStatus(){
   lcd.print("WIRE     OF   ");
   lcd.print(wiresCut+1);
   lcd.setCursor(11, 1);
void setBlade(char bladePos){
  switch (bladePos){
    case 'H': // home
      while (!isHomed){
        curTime = millis();
        if (curTime - lastTime > 100){
          lastTime = curTime;
          sensorVal = analogRead(PIN_SENSOR);
          if (sensorVal < 430){
            targetPos += 63;
            stepCut.moveTo(targetPos);
          } else {
            isHomed = true;
            stepCut.setCurrentPosition(0);
        stepCut.run();
    break;
    case 'R': // retract
      stepCut.moveTo(retractPos);
    break;
    case 'S': // strip
      stepCut.moveTo(stripPos);
    break;
    case 'C': // cut
    break;
void returnToMenu(){
  scrollPos = subMode;
  subMode = 5;
void printCursor(int cursorPos){
  //clear old cursor positions
  lcd.print(" ");
  lcd.setCursor(8, 0);
  lcd.print(" ");
  lcd.print(" ");
  lcd.setCursor(8, 1);
  lcd.print(" ");
  lcd.setCursor(12, 1);
  lcd.print(" ");
  switch(cursorPos){
    case 0:
      lcd.print(">");
    break;
    case 1:
      lcd.print(">");
    break;
    case 2:
      lcd.print(">");
    break;
    case 3:
      lcd.print(">");
    break;
    case 4:
      lcd.print(">");
    break;
void printMenu(){
  lcd.print(" QTY:    WRL:   ");
  lcd.print(" STL:    RUN CLR");
void resetParameters(){
  wireQuantity = 0;
  wireLength = 0;
  wiresCut = 0;
void getInput(){
  buttonOK.update();
  buttonRED.update();
    ledState = !ledState;
    digitalWrite(PIN_LED, ledState);
  encPos = encoder.read();
  if (abs(encPos - lastEncPos) > 4){ // did the encoder move one detent?
    if (encPos - lastEncPos > 0){ // positive
      scrollPos++;
    } else { // negative
      scrollPos--;
    lastEncPos = encPos;
Bill of Material:
Product Name Manufacturer Quantity
Buy Kit
Stepper Motor Bipolar 1 A Two Phase 3.4 ohm 6.5 mH
SANYO DENKI - SANMOTION 1 Buy Now
Stepper Motor Power Step High Torque Bipolar 294 in-oz 2.8 A Two Phase 1.1 ohm 3.8 mH
LIN ENGINEERING 1 Buy Now
TMCM-1070 -  Stepper Motor Driver, 2-Phase, Single Axis, 2.8A, 24V DC Output, USB, RS485, CAN TRINAMIC 1 Buy Now
Motor Driver R701 Microstepping Two Phase 12 to 80 Vdc 7 A 560 W 200 kHz LIN ENGINEERING 1 Buy Now
A100067 -  Development Board, Arduino Mega 2560 Rev3 RETAIL, ATmega2560 MCU, 54 3.3V I/O, 16 Analogue Inputs ARDUINO 1 Buy Now
1141 -  Assembled Data Logging Shield For Arduino ADAFRUIT 1 Buy Now
24-15112 -  Wire, PVC, Red, 22 AWG, 100 ft, 30.5 m STELLAR LABS 1 Buy Now
OLED Character Display ADAFRUIT 1 Buy Now
Pushbutton Switch Off(On SPST 125 V 50 V 400 mA Solder APEM 1 Buy Now
Incremental Encoder 5 VDC 2 Channels 60 rpm 24 Detents 24 Pulses PEC11R Series BOURNS 1 Buy Now
Hall Effect Proximity Sensor Flange Mount 55100 Series Analogue 4.5 to 5.5 Vdc HAMLIN 1 Buy Now
AC/DC Enclosed Power Supply(PSU ITE 1 Outputs 200 W 24 V 8.4 A TDK-LAMBDA 1 Buy Now
Additional Parts:
Product Name Quantity
SCHLEUNIGER CS 9100 “V” STYLE CUTTING AND STRIPPING BLADES
1
  • oled
  • stripper
  • automatic
  • arduino_vcp
  • manufacturing
  • vcp_arduino
  • friday_releasedj
  • wire cutter
  • adafruit
  • atmega2560
  • arduino_mega
  • automation
  • dj harrington
  • friday_release
  • e14presents_djharrigan
  • hutkikz
    hutkikz over 5 years ago +4
    I just thought you guys would like to see the machine I built inspired by DJ's excellent video!. www.youtube.com/watch I supersized it a bit and changed it up to use the parts and materials I had…
    dougw over 7 years ago in reply to DAB +3
    Have you tried a wire-wrap tool meant for stripping 30 gage Kynar? I actually end up using a low cost tool like this - with the stop adjusted properly:
  • juanecs
    juanecs over 6 years ago +3
    Where can I download the code? I know the video points to element14.com/presents but where specifically. Please
  • hutkikz
    I supersized it a bit and changed it up to use the parts and materials I had in my stash.
    I've had that piece of aluminum used for the main body over 20yrs waiting on the right project.
    The feed system is made from the print rollers, rods and bushings out of an old hp color laser jet printer. The drive roller is pinned.
    The cutter is the same as pictured in the comment above. I added a guide between the cutter and feed roller.
    It has a 4x4 keypad and 20x4 LCD and yeah.....one of these days I swear I'll actually finish the code(sure lol)
    It can handle the big 6"x7" (~15 lb.) wire spools and up to 12 awg wire,  tho I run mostly 16-18g
    Have gone thru 6 of those spools so far and it works great, The only thing I'd like to improve is
    I have to calibrate every spool of wire I think because of differences in dia. changing the steps per inch. IDK
    Thanks DJ with just the addition of a guide your basic design has proven quite good.
    Les
  • mrvolt
    mrvolt over 5 years ago in reply to hutkikz
    Hey Les,
    I'm glad my design was useful to you! Your design is super robust. The use of flush cutters is much more elegant (and cheaper) than my design.
    Please take and share more photos image
    DJ
  • selphb
    selphb over 5 years ago in reply to mrvolt
    DJ,
    I would like to discuss a project with you. Shoot me a message so we can connect.
    Regards,
    Brad
  • mrvolt
    mrvolt over 5 years ago in reply to selphb
    Hi Bradley,
    Apologies for the delay. I was unaware that I had to follow you to send PMs. Once that's accepted, I'll reach out!
    Best,
    DJ
  • selphb
    DJ,
    It is very strange the way they restrict communication on this platform with other members.
    Regards,
    Brad
  • selphb
    DJ,
    Regards,
    Brad
