Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi NOAA Satellite Receiver -- Episode 370
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:12 PM Date Created
  • Last Updated Last Updated: 30 Nov 2018 8:24 AM
  • Views 7552 views
  • Likes 10 likes
  • Comments 9 comments
element14 presents  |  AirborneSurfer's VCP Profile |  Project Videos
Emboldened by the success of his Raspberry PIrate radio, Matt indulges in some more radio hacking by building a specialized QFH antenna and a briefcase form-factor satellite receiver in an attempt to intercept "faxes" from OUTER SPAACEEE!!! Project TIROS is a self-contained, Raspberry Pi-based satellite signal reception system designed to automatically download images and data from NOAA's POES spacecraft as they pass overhead and display the data on an integrated LCD panel. In this video, Matt will walk through how to set up an RTL-SDR module with a Raspberry Pi for automated satellite downloads as well as how to design and build a quadrifilar helical antenna for polar-orbiting signal reception.
Supplemental Content:
  • What The Heck Is TIROS?
  • Newark TC-110 Tool Case Unboxing and Review
  • How To Tear Down a Computer Monitor
  • How To Set Up a Raspberry Pi as a NOAA Satellite Receiver with RTL-SDR
  • How To Build A QFH Antenna for NOAA Weather Satellite Reception
  • How To Convert an ATX PSU Into a Bench Power Supply
  • Project TIROS [OUTTAKES]
Bill of Material:
PartManufacturerQuantity
ATX 300W Power Supply w/Ball Bearing Fan
SPARKLE POWER1Buy Now
MEMORY CARD, MICROSDHC, UHS-I, 16GB
SANDISK1Buy Now
Raspberry Pi 3 Model B, 1.2GHz CPU, 1GB RAM, WiFi/BLE, 40 GPIO PinsRASPBERRY-PI1Buy Now
KEYBOARD, ULTRA SLIM, USB, BUILT-IN TRACKBALL KBK3NTU 1Buy Now
Tool Case, Aluminium, 6" Height, 18" Width, 13.5" DepthDURATOOL1Buy Now
USB Cable, USB Type A Plug, Micro USB Type B Plug, 305 mm, 1 ft, USB 2.0, BlackQUALTEK ELECTRONICS1Buy Now
Fan Finger Guard, Grille, 120mm Axial Fans, 120 mm, 104.8 mm, Steel, YesMULTICOMP1Buy Now
Axial Fan, AD12025 Series, 12 V, DC, 120 mm, 25 mm, 39.1 dBA, 87.87 cu.ft/minADDA1Buy Now
7 Segment LED Display, InfoVue, Red, 10 mA, 2 V, 3.5 mcd, 2, 14.22 mmLUMEX1Buy Now
RF / Coaxial Connector, BNC Coaxial, Straight Bulkhead Jack, Solder, 50 ohmAMPHENOL RF1Buy Now
RF / Coaxial Cable Assembly, SMA Straight Plug, BNC Straight Plug, RG316, 50 ohm, 6 ", 152 mmJOHNSON - CINCH CONNECTIVITY1Buy Now
Multiconductor Cable, Unshielded, 14 AWG, 50 ft, 15.2 mRCA1Buy Now
DC PLUG TO SCREW TERMINALS MALE 5.5X2.1MM 5PKVELLEMAN SA1Buy Now
Through Hole Resistor, 10 ohm, 10W Series, 10 W, ± 5%, Axial Leaded, 550 VNTE ELECTRONICS1Buy Now
DIN Rail Mount Terminal Block, 12 Positions, 24 AWG, 12 AWG, 2.5 mm², Screw, 10 AWEIDMULLER1Buy Now
Additional Parts:
Product NameQuantity
RTL-SDR
1
RG-6 cable (3 feet)
1
RG-6 cable (3 feet)
1
PVC pipe
1
  • e14presents_airbornesurfer
  • raspberry pi sdr
  • weather satellite
  • briefcase computer
  • raspberry pi
  • raspberri pi
  • noaa satellite receiver
  • noaa
  • sdr
  • weather satellite receiver
  • qfh antenna
  • rtl-sdr
  • friday_release
  • TIROS
    DAB over 7 years ago in reply to airbornesurfer +1
    Many years ago I was the IVV Engineer on a large integrated avionics development project where they put together communications, navigation and IFF RF receivers with digital signal processing. So I understand…
  • airbornesurfer
    airbornesurfer over 5 years ago in reply to neskin
    I can't see why there would be a problem. The download doesn't change, but it may take a little longer to process the image when you go to view it.
  • neskin
    neskin over 5 years ago
    I plan on doing this with my old 32-bit laptop. My question is Other than the RTL-SDR connecting to the antenna is their anything else this will need. Will this work on a 32-bit laptop running Linux and will their be additional interference or lower image processing.
  • airbornesurfer
    airbornesurfer over 6 years ago in reply to johnbussoletti
    Finally managed locate the original scripts that I based the project on. These should work for you without much modification.
    Project TIROS Bash Scripts
  • johnbussoletti
    johnbussoletti over 6 years ago
    Is there a link where one might find the bash shell scripts that you used?  The video only presents part of the schedule_satellite.sh script.  I can guess about the remaining content, but if you would make the scripts available, that would be a great help.
  • airbornesurfer
    airbornesurfer over 7 years ago in reply to aspork42
    Thanks!
  • aspork42
    aspork42 over 7 years ago
    Awesome Project!
    Many years ago I was the IVV Engineer on a large integrated avionics development project where they put together communications, navigation and IFF RF receivers with digital signal processing. So I understand your interest in RF. Lots of interesting things can be done if you know what you are doing.
  • airbornesurfer
    airbornesurfer over 7 years ago in reply to DAB
    Ha! Thanks!
    I would've used shrink wrap, but I didn't have any that would fit on the connection--everything in stock was either too big or too small!
    Let me know when you start messing around with the SDR! I love digging into the RF spectrum (as you might've noticed)!
    Nice build.
    I had to stop myself from screaming at the screen for you to use heat shrink tubing on the BNC connector, but I have used electrical tape myself many decades ago.
    I have thought about doing some RF receiver projects and even bought an SDR, but I have not had the time to build anything yet.
