Project Videos
  • Project Videos
Project Videos
Documents Hacked Fetal Detector Music Synthesizer -- Episode 375
  • Date Created: 17 Dec 2018 6:18 PM Date Created
  • Last Updated Last Updated: 4 Jan 2019 8:24 AM
  • Views 5862 views
  • Comments 12 comments
element14 Presents  |  MAYER MAKES VCP Profile  |  Project Videos
Fleamarkets can hold a lot of junk but also treasures, Clem bought a 70's medical device which was used to examine the heartbeat of unborn children and hacks it into a retro style synthesizer.you can use your own heartbeat or even that of any person(born yet or not) to alter the sound of the device. It features a 10 Stage Sequencer and 5 different filters to create various sounds and rhythms.
Bill of Material:
Product Name Quantity
Buy Kit
555 Timer IC DIP8
3 Buy Now
SPDT switch 5A Panelmount
20 Buy Now
10 Turn Potentiometer 5kOhm 1 Buy Now
Decade counter/Divider IC
1 Buy Now
Knob Round 6mm / 50mmm with position marker
1 Buy Now
Quad Amplifier IC
1 Buy Now
Ansmann NIMH AA 1,3Ah 4-Pack
2 Buy Now
Resistor 10kOhm
10 Buy Now
Resistor 33kOhm
10 Buy Now
Electrolytic Capacitor 10uF
2 Buy Now
Electrolytic Capacitor 100uF
2 Buy Now
Additional Parts:
Fetal Detector from the Fleamarket, or get a new one for cheap on the internet.
1
Order a wild selection of Caps and resistors to experiment around until you get the desired sound.
1
Differently colored wire to keep track of all the connections.
1
  • capacitor
  • potentiometer
  • arduino uno
  • e14presents_mayermakes
  • green tech
  • 555_timer
  • green technology
  • fetal detector music synthesizer
  • decade counter
  • resistor
  • summer of green technology
  • friday_release
  • mayermakes
  • music synthesizer
  • mayermakes
    mayermakes over 7 years ago in reply to beacon_dave +2
    I actually made something similar to that a while back: : www.youtube.com/watch https://www.youtube.com/watch?v=CcfS_xI3Pdk it uses 2 555 timers and a FLed as a crude form of a 2 step sequencer, you can…
  • mayermakes
    mayermakes over 7 years ago +1
    Some facts were left onm the cutting floor: this is a fetal detector--> it operates with doppler radar not ultrasound ultrasonic devices were introduced for this purpose much later. the Filters are Simple…
    beacon_dave over 7 years ago +1
    For some more fun with synths then I recall that there was an article in this month's HackSpace magazine (issue number 14), which may be of interest to some community members: https://hackspace.raspberrypi…
  • mayermakes
    mayermakes over 7 years ago in reply to jimlberto
    I wish I could just post them or give asingel link, but I made up the circuit as I built it and changed a lot over the course of the project but here arethe circuits i took as a starting point, I doubt you migrth get a hand at the same Fetal detector but maybe some different piece of old tech to utilize so these links should help you:
    https://lmgtfy.com/?q=Atari+Punk+console+circuit&s=g
    Basic sound generator I used 2 of these to get a high and a low note,( the low is nearly unhearable in the video)
    the Pitch pot is connected to the main big poti i built into the machine
    https://lmgtfy.com/?q=Baby+step+sequencer&s=g
    The sequenzer part is based on this circuit , I only added LEDs and connected inputs and outputs to the other sections of the machine
    https://lmgtfy.com/?q=Low+pass+filter+rc&s=g
    The FIlters are just Low Pass R/C filters(a cap and a resistor) in random values, trial and error showed me some that sounded interesting.
    the Fetal signal gets mixed into the added electronics just before the Sequenzer stage. the sequenzers signal is fed back into the sound generators when the "Feed" switch is activated.
    Hope  this info helps you in building your own noise machine!
  • jimlberto
    jimlberto over 7 years ago
    hi, is there a way to see the actual schematics of this project? 555 to 4017 to 324 plus resistors switches and wires, is not quite specific, you know?
    maybe you can point to a link where I can set the pieces together without making a mistake? perhaps?
  • aptbartmess
    aptbartmess over 7 years ago in reply to mayermakes
    Cute!
  • mayermakes
    it uses 2 555 timers and a FLed as a crude form of a 2 step sequencer, you can alter speed and pitch with covering the photoresistors and the fled, modulate with covering the speaker and activate the sound with the pushbutton
    beacon_dave over 7 years ago in reply to mayermakes
    How about something like this 'playWATCH' synth:
    https://www.hackster.io/janost/the-playwatch-61db7b
    but incorporating an IR photoplethysmography pulse sensor into the design to trigger it from heartbeats ?
  • mayermakes
    mayermakes over 7 years ago in reply to aptbartmess
    thanks. I try my best.
  • aptbartmess
    Excellent! You're an engaging host with a knack for explaining things.
  • mayermakes
    Thank you! Well if you insist I'll think about some future projects with experimental instruments, maybe something with MIDI or homemade guitar effects.
  • aptbartmess
    What a super project! I'd love to see more of your experiments with sound making instruments.
  • mayermakes
    thanks I got to take a look at that!
