Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi 4 Music Player w/ Analog Controls -- Episode 435
  • Date Created: 19 Feb 2020 5:59 PM Date Created
  • Last Updated Last Updated: 28 Feb 2020 8:24 AM
  • Views 8708 views
  • Likes 8 likes
  • Comments 15 comments
I love the Volumio music player software for the Raspberry PI, but I am tired of digging through my pockets for my phone to change the volume or pause a song. In this episode, we are going to fix that by adding a bunch of buttons and knobs in addition to a touchscreen display to control Volumio 100% from hardware and without the need for a web browser or app!
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
TRANSCEND 16GB MicroSD Card, Preloaded with NOOBS (V2) OS Installer for Raspberry Pi TRANSCEND 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 4 Model B, BCM2711 SoC, 4GB DDR4 RAM, USB 3.0, PoE Enabled RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Raspberry Pi 7" Touch Screen Display with 10 Finger Capacitive Touch RASPBERRY-PI 1 Buy Now
STONTRONICS AC/DC Power Supply, 1 Output, 15.3 W, 5.1 V, 3 A STONTRONICS 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 2 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
TE CONNECTIVITY IC & Component Socket, 16 Contacts, DIP Socket, 2.54 mm, 7.62 mm, Phosphor Bronze TE CONNECTIVITY 1 Buy Now
MICROCHIP Analog to Digital Converter, 10 bit, 200 kSPS, Pseudo Differential, Single Ended, Serial, SPI MICROCHIP 1 Buy Now
Additional Parts:
Product Name
Adafruit CAP1188
SPDT Toggle Switch
10k Linear Taper Potentiometer
Protoboard
Slide Pot - Motorized (10k Linear Taper)
Resources_Pi4MusicPlayer.zip
element14 presents  |  About Kaleb |  Project Videos
  • mcp3008
  • kaleb
  • e14presents_kalebclark
  • python
  • microchip
  • itw
  • cap1188
  • programming
  • raspberry pi touch screen
  • volumio
  • raspberry pi 4
  • raspberry pi
  • analog to digital converter
  • stontronics
  • e14p_KC
  • friday_release
    DAB over 6 years ago +1
    Nice project. DAB
  • airbornesurfer
    airbornesurfer over 6 years ago +1
    Super rad! Though I kinda want to hear more of this band you were in now.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to andrewcrice +1
    Andrew, that blew my mind. I am an audio engineer and own a few control surfaces with motorized faders that DO have conductive handles on them. But it *never* crossed my mind to just use one of those.…
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to e14 Contributor
    Thank you!
    Below is the best I have for a schematic. Unfortunately, it does not include the CAP1188 Capacitance sensor for the fader, but if I recall correctly I used SPI for that to connect to the Raspberry PI. Adafruit has great documentation for that device.
    For the parts, if you look in the "Additional Parts" section above it describes the fader, and which type of pot I used for the volume. Those faders are sometimes difficult to find, but if you just google the description above you will get some hits. Just make sure you find one that is the right length for your project. They vary in size. The fader has contacts for a potentiometer just like you would expect, connections for the motor, and another lead for capacitance.
    I am in the middle of a move, and that device is still packed up. But if you have troubles with that part I can try to find it and trace out the fader portion.
    Here is the schematic that I was able to dig up.
    Good Luck with your build!
    -Kaleb Clark
    e14 Contributor over 5 years ago
    Kaleb,
    great project. I will build it for my 5year old daughter with a horse riding on the slider in front of a princess castle being the player. I am searching for a good idea for weeks now and yours is second to none.
    I shall try to use a waveshare 7display and I further plan to use a simpler web ui rather than the official volumio.
    Recourses zip seem to only have stl files in it. I cannot find wiring diagrams and a bit of explanation around the hardware, in particular what motor specs for the slider and why and what kind of volume poti rather than a rotary encoder?. Any chance to post wiring and some more info, as this would make a built much less try and error.
    Cheers Andreas
  • nik91
    nik91 over 5 years ago
    Hi,
    Nice project. I am trying to do it but stuck in connections, can you help me with the Schematics.
  • mr1980
    mr1980 over 6 years ago in reply to KalebTheMaker
    Oh that’s why I thought It was so great, I’ve had a little time in the studio myself    not a lot, think entourage and trumpet instead of front man or songwriter
  • jeffpetersen
    jeffpetersen over 6 years ago
    Hi, think the volume would work better with a log pot.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to tjb167
    They sure are Travis. Check the zip file on this page. Should all be in there.
    -Kaleb
  • tjb167
    tjb167 over 6 years ago
    Are the STL files available for the 3D printing the enclosure?
  • KalebTheMaker
    Andrew, that blew my mind. I am an audio engineer and own a few control surfaces with motorized faders that DO have conductive handles on them. But it *never* crossed my mind to just use one of those. I guess that is just how deep in DIY I was on this project!
    I would still like to make one, but if that does not pan out, Ill probably go that route. Though in the ~week of using the device it really has not been an issue. I can still grab what is there and move it. Mostly aesthetic at this point.
    Thanks for the great idea and jolt back into reality! haha
    -Kaleb
  • andrewcrice
    andrewcrice over 6 years ago
    What a fun project - great job. I was determined to rebuild a vintage radio and replace the tuner's linear needle with a similar motorized pot. Based on the research I did, it was the most reliable way to build an inexpensive and compact linear actuator for a short-travel lightweight load (needle) with builtin encoding. I didn't need the conductive feature for my project, but I did learn that such knobs are available for the intended application (audio mixing boards). You can buy these knobs (and sometimes the pots too) pulled from broken mixing boards. If you want to buy a new knob, Selco advertises them available in quantities as low as one. Their website indicates that conductive knobs are available, but does not indicate which part numbers have that feature. https://www.selcoproducts.com/knobs/slider-knobs
    I've also used Volumio in projects and love it. A feature I really longed for, and would like to have time to develop and share as a plugin someday, is integrated control for a I2C FM Tuner module.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to mr1980
    Thanks, Thomas, I got the idea for the dim functionality from studio monitor control systems. Very handy when you need to talk to someone but not interrupt playback.
