Project Videos
  • Project Videos
Project Videos
Documents DIY Motorized Zoom for Your DSLR -- Episode 437
  • Date Created: 5 Mar 2020 3:54 PM Date Created
  • Last Updated Last Updated: 13 Mar 2020 8:24 AM
  • Views 6985 views
  • Likes 8 likes
  • Comments 13 comments
Clem's Video production is a one-man-show.  He has to switch back and forth between being the subject and the cameraman. Constantly moving around the workshop for every single little correction is very tedious. Why not upgrade any common DSLR with a remotely controlled Zoom/Focus? Commercially available motorized zooms and focus pulling devices are very expensive, so Clem develops his own cheap and flexible solution and finds out if is it worth building this sort of camera equipment yourself. What kind of expensive equipment should he try to recreate next?
Bill of Material:
MULTICOMP PRO Navigation Switch, 200 gf, 5 V, 1 mA, Solder, 3 Multicomp 2 Buy Now
SEEED STUDIO ESP8266 WiFi Module Breakout Board SEEEDSTUDIO 2 Buy Now
ADAFRUIT PowerBoost 1000 LiPo Charger 5V 1A Boost Adafruit 2 Buy Now
MIKROELEKTRONIKA Rechargeable Battery, 3.7 V, Lithium Polymer, 2 Ah, Wire Leads Mikroelektronika 2 Buy Now
MULTICOMP 3D Printer Filament, 1.75 mm, PLA, Black, 1 kg MULTICOMP 1 Buy Now
STMICROELECTRONICS Fixed LDO Voltage Regulator, up to 30V, 1.3 V Drop, 3.3V/1.5A out, TO-220-3 Pins ST 2 Buy Now
Supplemental Content:
  • PCB available at Aisler.net:  https://aisler.net/p/YQYOREEF
Additional Parts:
Product Name
Bolts M3 & M2
3D printer
optional: camera mount system, Files for DIY version are included but,may not be suitable for your camera.
Headers , wires and solder
Slide switch, I already had in stock
Resources_MotoZoom.zip
element14 Presents  |  About Clem  |  Project Videos
  • how to dolly zoom
  • diy remote
  • how to send date from esp8266
  • esp8266 access point
  • voltage regulator
  • videography hacks
  • clem
  • motorized focus
  • wifi udp
  • esp8266 wifi
  • filming diy
  • e14presents_mayermakes
  • focus pulling
  • diy
  • vertigo
  • esp8266
  • esp8266 udp
  • autofocus
  • seeed studio
  • motorzoom
  • diy filmmaking
  • esp8266 data transfer
  • lipo
  • multicomp
  • videographer
  • film hacks
  • zoom
  • autozoom
  • rechargeable battery
  • st
  • wifi controller
  • filmmaking equipment
  • friday_release
  • mayermakes
  • e14p_CMM
  • esp8266 project
  • mayermakes
    mayermakes over 6 years ago in reply to celcius1 +2
    I never rule out revisiting a project. I chose to use gears for a simple reason . friction does not work. I tried. To have friction working(every lens has a different surface which makes things more difficult…
  • mayermakes
    mayermakes over 6 years ago in reply to fmilburn +1
    Hi. Once the lens reaches the max rotation the ring should slip, or the gears skip. There is no electronic endstops as the lenses can be very different. In case you ant to have a non reversal endpodition…
  • celcius1
    celcius1 over 6 years ago +1
    Hi Clem, Great concept but way over complicated, there is a much simpler way to do this, and keep the 3D printing to a minimum, Why put attachments on the camera lens when there is lenses available that…
  • fmilburn
    fmilburn over 6 years ago
    Hi Clem,
    Nice work and highly useful.  You may have covered it but if so I missed it.  Is there something that provides feedback to stop it from trying to over rotate the lens?  Is it just that a rack is the right length to prevent over rotation?  I should look at the files you have provided.
    Frank
    EDIT:  By the way, great topic too.  This is the kind of project I would be interested in attempting.
    beacon_dave over 6 years ago
    I thought about doing something similar to this about 10 years ago but it was to drive a C-Mount lens on a 5Mpix CCTV IP camera which only had manual control.
    The cameras were often located in remote locations and it proved difficult to focus them accurately out in the field. The cameras used had a real time composite video output which was ok for framing and rough focusing, but the high resolution image was only available over the network or to CF card storage and was delayed.
    The plan I had at the time was to use a belt drive around the lens adjustment ring along with a motor to drive it just to be able to nudge it into precise focus remotely whilst viewing the full resolution image over the network in the shelter of the office.
  • davedarko
    davedarko over 6 years ago
    Highly useful, I need that for focus though image
