Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi 4 DVR -- Episode 444
  • Date Created: 28 Apr 2020 5:46 PM Date Created
  • Last Updated Last Updated: 1 May 2020 7:24 AM
  • Views 4491 views
  • Comments 10 comments
My smart TV is pretty, well, smart. But it can't do everything. But is there anything that can't be improved with a Raspberry Pi? Especially when paired with the official RPi TV Hat.
Bill of Material:
RPI3-MODBP - Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
RPD-60A - POWER SUPPLY, MEDICAL, AC-DC, 2 O/P, 49W Mean Well 1 Buy Now
4301.3202 - Power Entry Connector, KEA-Print Series, Plug, 250 VAC, 10 A, Panel Mount, Through Hole SCHURTER 1 Buy Now
SJKWHB - CONNECTOR OUTLET, RJ45 UTP, JACK, CAT6 TUK 1 Buy Now
MP000921 - SMALL ENCLOSURE, ABS, BEIGE/CLEAR MULTICOMP PRO 1 Buy Now
Additional Parts:
Product Name
Official Raspberry Pi TV HAT
F-Type to MMCX Plug 150mm lead RG316
F-Type to DVB-T Converter
Pi4DVR_Resources.zip
Raspberry Pi 4 DVR
element14 presents  | About David Edwards  |  Project Videos
  • dvr
  • david edwards
  • tv hat
  • raspberry pi zero
  • rpi tv hat
  • raspberry pi
  • tv recording
  • headless raspberry pi
  • multicomp
  • official raspberry pi tv hat
  • tvheadend
  • e14presents_davidedwards
  • friday_release
  • network video recorder
    DAB over 6 years ago +1
    Nice build. DAB
  • a531016
    a531016 over 6 years ago in reply to DAB +1
    Thanks!
  • kk99
    kk99 over 6 years ago +1
    Good job !
  • a531016
    a531016 over 6 years ago in reply to steve_t429
    Ahh, thanks for sharing!
    I should say that I was using a server based on Debian running SMB shares as my network storage!
  • steve_t429
    steve_t429 over 6 years ago
    Great tutorial, but had to add an additional parameter "vers=3.0" - equivalent to the SMB level - to get the share to work with my Synology NAS (DS918+).
  • kk99
    In my opinion is the configuration will be similar when you use different USB tuner dongle.
  • a531016
    a531016 over 6 years ago in reply to ts_meyer
    I don't believe the US uses the DVB T2 System that the RPi TV HAT supports. The same project should work with other USB tuners that will work though?
  • a531016
    a531016 over 6 years ago in reply to zepperdude
    You should be able to find USB tuners that wortk with the ATSC 3.0 standard. The rest of the project will work in the same way, just check that the one you chose will work with TVHeadEnd (here).
  • ts_meyer
    ts_meyer over 6 years ago
    Does this TV Hat work yet in the USA? The original version did not
  • zepperdude
    zepperdude over 6 years ago
    Anything for ATSC?
  • kk99
    Good job !
  • a531016
    Thanks!
    Nice build.
