Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi 4 VR Conference Call Assistant -- Episode 459
  • Author Author: cstanton
  • Date Created: 22 Jul 2020 3:18 PM Date Created
  • Last Updated Last Updated: 14 Aug 2020 7:24 AM
  • Views 6030 views
  • Comments 15 comments
It’s difficult to take part in conference calls. The 2d nature of the call doesn’t allow social interaction. What if you could look at people in your conference call using a virtual reality headset? A picture of you would move left and right as your head moves left and right. Other attendees can look around and chat to the person they want to talk to. Lorraine shows how to setup a first person view raspberry pi that connects to a virtual reality headset or a simple browser window. This project has lots of potential outside of conference calls such as security cameras, nature cameras and first person view robots.
Bill of Material:
RASPBERRY-PI Daughter Board, Raspberry Pi Camera Board, Version 2, Sony IMX219 8-Megapixel Sensor Raspberry Pi 2 Buy Now
PIMORONI PAN-TILT HAT FULL KIT PIMORONI 2 Buy Now
RASPBERRY PI 3 Raspberry Pi 2 Buy Now
Raspberry Pi Power Supply Raspberry Pi 2 Buy Now
SD Card TRANSCEND 2 Buy Now
Additional Parts:
Product Name
A VR HEADSET, PREFERABLY A SIMPLE CARDBOARD ONE
code.zip
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • vr headset
  • vr tracker
  • virtual reality tracker
  • Raspberry Pi Power Supply
  • virtual reality headset
  • Raspberry Pi Camera
  • vr tracking camera
  • pimoroni
  • raspberry pi virtual reality tracker
  • raspberry pi
  • binary camera
  • lorraine underwood
  • raspberry pi virtual reality conference call
  • raspberry pi 3
  • e14presents_lunderwood
  • friday_release
  • Workshopshed
    Workshopshed over 6 years ago +5
    I like the idea and had thought about a telepresence robot for when I'm working remotely and the rest of my team are back in the office. Have you see Ross Atkin's Smartipresence robot using cardboard plus…
  • lorrainbow
    lorrainbow over 6 years ago in reply to Workshopshed +4
    hi Andy, thanks for the links. Yeah, I love Ross' robot! https://www.kickstarter.com/projects/rossatkin/smartipresence-cardboard-telepresence-robot
  • lorrainbow
    lorrainbow over 6 years ago in reply to beacon_dave +4
    Hi Dave, In a conference room, sitting around a table you won't really be able to just move your eyes to see everyone. You'd have to be sat quite far back! Video of the other people would be awesome. If…
    beacon_dave over 6 years ago in reply to lorrainbow
    "...I'd love the play around with a 360 camera..."
    lorrainbow perhaps speak to Pete Hurst in ISS - he has a Polycom CX5500 that you could play with.
    It may be a bit too specific for your experimental purposes - depends how much documentation there is available on the API. It was designed primarily to work with S4B / Lync web conferencing. If used standalone as a USB webcam it behaves as an autotrack camera.
  • lorrainbow
    I'd love the play around with a 360 camera.. it kind of negates the need for a moving camera which I kind of like for the sound and movement! But a 360 camera accessed by a vr headset would be cool
    beacon_dave over 6 years ago in reply to Workshopshed
    I've used the likes of the roundtable ones which have the 360 panoramic camera and audio direction detection which then crops the video to centre it on the area it thinks the sound is coming from.
    However I was thinking more of the ability to have multiple simultaneous channels, so that two people looking at each other could talk on a separate channel from the person currently speaking.
    This would get around the problem of two people quickly commenting on something that the active speaker has just said without interrupting the main conversation.
  • Workshopshed
    Workshopshed over 6 years ago in reply to beacon_dave
    I once did some video conferencing with a "bot" in the middle of the table that had sound sensors and turned to whoever was speaking. It didn't turn 360 as it had multiple cameras and could switch between them.
    Perhaps another interesting area to investigate might be with the audio channels. If two people are looking at each other, then perhaps there could be an option to duck the main room audio to permit a secondary conversation to take place between the individuals. This could improve on in-person conferences as it removes that irritating problem when you have two people constantly trying to talk across you but it also allows for them not to lose out on the value of a spontaneous quick discussion.
  • kmikemoo
    kmikemoo over 6 years ago
    Loved it!  Really out of the box thinking and, yes... just a bit creepy. imageimage
    DAB over 6 years ago
    Very nice episode.
    There is a lot of potential for your setup, both with tracking and using VR.
    Hi Lorraine.
    Indeed, in real life head movement will vary with seating layout and distance. With VR it will also depend on the field of view of the cameras.
    As you say, to see everyone in a room, you would have to move your head, but if you are just looking at the two or three people positioned directly opposite, then at times I suspect that you may only be moving your eyes between people as it takes less effort. If this is the case then in some instances you may see the mannequin move to look at you but other times not.
    With the VR setup I suspect you could perhaps limit the horizontal field of view to cover just one person so that you always had to move your head to look at someone else, but that would end up giving you tunnel vision.
    This will also likely depend on how you intend to place the mannequins. With the general move to replace physical space with virtual space these days then the conference room may end up having to be scaled down in size. Do you then place the mannequins optimised in a small circle in the corner of an office or do you stick with the more traditional layouts where you can never see the people to the extreme left or right of you ?
    Also, how do you start to include presentation content. When your mannequin turns away to look at the presentation screen, then ideally your video feed needs to switch to the on-screen content instead.
    (Mixed mode conferences are another issue that are cropping up where you may have 7 participants in the room and 70 remote, or alternatively 70 in the room and 7 remote.
    Also there are now requests coming in for multi-site conferencing where you a) either stay at home and remote in b) drive to your nearest local centre to participate in a satellite group, c) travel to the main host venue.
    Then beyond that there are the international conferences where the main conference venues are located across separate countries, each with country specific satellite venues and remote participants all wanting to communicate with each other as naturally as possible.)
    I think the head tracking makes it a more natural user experience than the desktop virtual joystick control. However perhaps it needs more of a lighter weight smart glasses type solution to reduce the bulk of the VR headset. However the head tracking takes you away from the desktop device so everything has to be accessible through the VR.
    (Looking back we had remote camera control on the old Tandberg video conference units back in the 90's. People got tired of it quickly though and ended up sticking with the one wide angle view for the duration.)
    Network bandwidth has always been an issue with conferencing as it quickly adds up as the numbers of participants increase. As bandwidth increases, so does expectations of image quality. Minimising latency is another ongoing issue.
    Have you looked at WebRTC which is gathering momentum ?
  • lorrainbow
    lorrainbow over 6 years ago in reply to balearicdynamics
    Hi Enrico
    Heres the code
    https://github.com/Lorrainbow/headconf
    During the video I thought i got the 2nd servo working up and down but it wasn't actually fully working. The 2 servos never worked together- for example the head didn't move diagonally.
    I used eulur angles. Quaternion angles would have been better but I couldn't get my head around the maths.
  • lorrainbow
    Hi Dave,
    Video of the other people would be awesome. If you all use the website and not the VR headset then you could see everyone and their facial expressions. I'd worry about home bandwidth there with sending and receiving video. But there's lots of future potential with this project!
