Project Videos
  • Project Videos
Project Videos
Documents Particle Voice Recognition for Home Appliances -- Episode 464
  • Date Created: 15 Sep 2020 7:01 PM Date Created
  • Last Updated Last Updated: 18 Sep 2020 7:24 AM
  • Views 5088 views
  • Comments 10 comments
I found these voice recognition modules that work with Arduino and have always wanted to test them in a project. Lets see if this can recognize the song my dryer plays when it's done with it's cycle!
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Bill of Material:
PARTICLE Development Board, Photon, P-zero Module, IoT, WiFi Development, With Pin Headers PARTICLE 1 Buy Now
DIALIGHT LED, Diffused, Red, Through Hole, T-1 3/4 (5mm), 10 mA, 2 V DIALIGHT 1 Buy Now
DIALIGHT LED, Diffused, Green, Through Hole, T-1 3/4 (5mm), 10 mA, 2.3 V, 565 nm DIALIGHT 1 Buy Now
Additional Parts:
Product Name
Elechouse Voice Recognition Module V3
ApplianceNotifier_Resources.zip
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • particle
  • photon
  • voice recognition
  • dialight
  • e14p_KC
  • friday_release
    beacon_dave over 6 years ago +3
    Did you try sampling on the end part of the tune rather than the beginning ? It sounds like the dryer stops spinning down before the tune finally runs out, so may be able to match on the tune as it ends…
  • KalebTheMaker
    KalebTheMaker over 6 years ago +3
    kmikemoo , @beacon_dave Good ideas, I did not think of that. The last eight notes are a unique pattern (yes, I still have that tune stuck in my head!), I can retrain on those last eight and see if it works…
  • kmikemoo
    kmikemoo over 6 years ago +2
    KalebTheMaker Brilliant application. You mention that the dryer song repeats itself. If the logic is "turn the dryer OFF", "play the song", I'm with beacon_dave on sampling later in the song. I'm guessing…
  • aspork42
    aspork42 over 6 years ago in reply to michaelklos
    https://www.element14.com/community/people/aspork42/blog/2020/10/12/building-a-smart-home-audio-notification-system
    I just posted this project using a library for the ESP8266 which can do text to speech via an MQTT message. The pronunciation and quality is pretty poor but it works. I ended up using an online speech synthesis system and saving pre-recorded mp3s for the announcements that don't require "on the fly" text to speech.
    The video in the post only shows the mp3; not the text to speech
  • michaelklos
    michaelklos over 6 years ago
    Anyone have any Good Text to Speech products/libraries/examples?
  • aspork42
    That's cool! I have found out the hard way that despite my iPhone having great background noise cancelation, that must be more of a software feature. When calling from apps like Teams or WhatsApp, the mic works poorly and amplifies background noise.
    So the module you have must be a little /too/ simple and hearkens to the early days of voice assistants where one had to repeat themselves 5 times and say things /juuuuuust/ right for it to work.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to mp2100
    Good idea, I will try that tomorrow while I try the other suggestions from Mike and Dave.
    -Kaleb
  • mp2100
    mp2100 over 6 years ago
    Nice idea to simplify life.  Maybe placing the microphone/photon further away, maybe outside the laundry romm would make the background noise less of a problem?
    I'm not sure why the voice recognition module doesn't have a link, so hey, I know how to use duckduckgo, so I'll post it.
    Speak Recognition, Voice Recognition Module V3 [AD_VR3] - $28.00 : Elechouse, Arduino Play House
    The price is reasonable.
  • KalebTheMaker
    kmikemoo, @beacon_dave
    Good ideas, I did not think of that. The last eight notes are a unique pattern (yes, I still have that tune stuck in my head!), I can retrain on those last eight and see if it works.
    Ill let you guys know how that goes.
    Thanks again
    -Kaleb
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to DAB
    Thanks DAB, It was an interesting and fun try.
    -Kaleb
  • kmikemoo
    KalebTheMaker  Brilliant application.  You mention that the dryer song repeats itself.  If the logic is "turn the dryer OFF", "play the song", I'm with beacon_dave on sampling later in the song.  I'm guessing that the logic must be "play the song" x times, "turn the dryer OFF".  Crazy thought... simple high-pass filter on your microphone input.  Maybe that will simplify the sample to the point where the background rumble doesn't affect it.
    Did you try sampling on the end part of the tune rather than the beginning ? It sounds like the dryer stops spinning down before the tune finally runs out, so may be able to match on the tune as it ends ?
    DAB over 6 years ago
    Interesting project and module.
