Project Videos
  • Project Videos
Project Videos
Documents Lego Raspberry Pi HQ Camera -- Episode 465
  • Date Created: 15 Sep 2020 7:55 PM Date Created
  • Last Updated Last Updated: 25 Sep 2020 7:24 AM
  • Views 8536 views
  • Likes 19 likes
  • Comments 28 comments
Ever thought that kids get much better looking gadgets, or toys look more fun that their real versions? Me too! So we’re going to build a Lego camera into a fully working telephoto camera using a RaspberryPi and the High Quality Camera with 16mm telephoto lens.  Can I make a pretend camera into a real working camera that is actually worth using? Let's find out!
Supplemental Content:
  • GitHub link for the code, wiring guide and lego designs
  • Link to the building instructions, Camera is book 2
Bill of Material:
Raspberry Pi 3 Model A+ RASPBERRY-PI 1 Buy Now
RPI-HQ-CAMERA RASPBERRY-PI 1 Buy Now
RPI-16MM-LENS RASPBERRY-PI 1 Buy Now
PIM185 - SHIM LiPo/Li Ion Battery Power Supply Interface Board For Raspberry Pi Pimoroni 1 Buy Now
1578 - Rechargeable Battery, 3.7 V, Lithium Polymer, 500 mAh Adafruit 1 Buy Now
TL1107AF180WQ - SWITCH, TACTILE, SPST, 50mA, 12VDC E-SWITCH 1 Buy Now
Tactile Switch, FSMJ Series, Top Actuated, Through Hole, Round Button, 160 gf, 50mA at 24VDC ALCOSWITCH - TE CONNECTIVITY 1 Buy Now
Additional Parts:
Product Name
Lego Set 41346
Extra Lego Bricks, List on Github
element14 presents
element14 presents  |  About Katie |  Project Videos
  • raspberry pi hq camera
  • LEGO
  • e14p_KD
  • raspberry pi battery power
  • e14presents_kdumont
  • te connectivity
  • raspberry pi
  • 16mm telephoto lens
  • katie
  • programmable logic
  • adafruit
  • Raspberry Pi 3 Model A+
  • friday_release
  • high quality camera
  • e-switch
    balearicdynamics over 6 years ago +4
    Genial the idea of gluing the bricks together and then drill them. A good alternative to 3D printing
  • Fred27
    Fred27 over 6 years ago +4
    A nice project combining two great ideas. The Lego abuse with MEK ( Kraggle ) and Dremel was a bit painful though!
    DAB over 6 years ago +3
    Good build and honest appraisal of the result. As an engineer I would say you were functionally successful. DAB
  • cchaves
    cchaves over 6 years ago
    Great job on the build.  I suggest ussting the 3.5 touch LCD.    thank you for sharring
  • davedarko
    davedarko over 6 years ago
    since the LEGO was bought for this purpose and you don't see a future version of yourself longing for that nostalgic feeling of when you got the kit for the first time... it's just awesome pink plastic to work with. LEGO will be AR in 5 years anyway and then you'll get all the kits to play with anyways ;D
  • hifromkatie
    hifromkatie over 6 years ago in reply to DAB
    Thanks image
  • hifromkatie
    hifromkatie over 6 years ago in reply to kmikemoo
    Thanks, I was planning on trimming it down, but the length felt just right when I tried it. If it was for a kid then it might need to be lower for smaller hands
  • hifromkatie
    hifromkatie over 6 years ago in reply to balearicdynamics
    Thanks, I was between doing it this way, or 3D printing a lens holder "brick", however went with doing it this way as I felt I'd need to glue the rest of the camera together anyway, I didn't fancy picking up all the pieces from the floor whilst out of the house.
  • hifromkatie
    hifromkatie over 6 years ago in reply to fmilburn
    Go for it, would be great to see it when your done!
  • hifromkatie
    hifromkatie over 6 years ago in reply to aspork42
    Thanks.
  • hifromkatie
    hifromkatie over 6 years ago in reply to jkutzsch
    Thanks. I like to do random things just to see if it's possible, the projects that don't need to be done usually end up being much more fun to do!
  • jkutzsch
    jkutzsch over 6 years ago
    Great job, I love the idea and implementation!  So many times you hear people saying that there is no reason to do/make this when what comes on our phone is so much better (or similar).  Where as you have shown that Makers need to Make!
  • hifromkatie
    hifromkatie over 6 years ago in reply to Fred27
    I'm not usually a advocate of mixing kraggle and Lego, however this was an exception, as it really wouldn't have worked without it. I though the end result would be cool enough to make the sacrifice!
    The only times I've previously used it was for similar reasons (making keyrings)
