Project Videos
  • Project Videos
Project Videos
Documents IoT Arduino NTP World Clock with SPI Display -- Episode 476
  • Date Created: 8 Dec 2020 7:51 PM Date Created
  • Last Updated Last Updated: 11 Dec 2020 8:24 AM
  • Views 6308 views
  • Likes 10 likes
  • Comments 8 comments
I work with people in many different time zones, and have always wanted an ‘at a glance’ world clock so I can see what time it is in their time zone. But I want mine to be configurable and synchronized with NTP, so I am going to build it!
Supplemental Content:
  • Download code from Github:  https://github.com/KalebClark/ArduinoClock
Bill of Material:
ARDUINO NANO 33 IOT DEV BRD, ARM CORTEX-M0+ MCU ARDUINO 1 Buy Now
VISHAY 7 Segment LED Display, Multiplex Mode, Green, 20 mA, 2 V, 4 mcd, 4, 10 mm VISHAY 2 Buy Now
ADAFRUIT Add-On Board, PiTFT Plus Raspberry Pi HAT, 3.5" TFT Screen, 480 x 320, Capacitive Touchscreen ADAFRUIT 1 Buy Now
TRIPP-LITE USB Cable, Type A Plug to Micro Type B Plug, 3 m, 10 ft, USB 2.0, Black TRIPP-LITE 1 Buy Now
BOURNS Rotary Encoder, Mechanical, Incremental, 24 PPR, 24 Detents, Vertical, With Momentary Push Switch BOURNS 1 Buy Now
LED DISPLAY DRIVER, 8 DIGIT, DIP-24 MAXIM INTEGRATED 1 Buy Now
Additional Parts:
Product Name
Small Proto board
10kohm Resistor
NTPWorldClock_Resources.zip
Kaleb_013-STL-Files.zip
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • vishay
  • kaleb
  • e14presents_kalebclark
  • clock
  • arduino nano
  • tft
  • diy
  • seven segment display
  • ntp
  • friday release
  • time
  • bourns
  • adafruit
  • e14p_KC
  • friday_release
  • tripp-lite
  • mayermakes
    mayermakes over 5 years ago +2
    mid of the episode ..suddenly " are you an Engineer or maker?" YES..thats me..no really thats me totally cought me off guard..answering to my own voice.
  • jenniferl
    jenniferl over 5 years ago +2
    Very nice, Kaleb! I like the "why buy one when you can build it" philosophy!! Did you consider adding AM/PM indicators for the two external displays? It looks like there might be room on the associated…
    DAB over 5 years ago +1
    Nice build. DAB
  • navadeepganeshu
    navadeepganeshu over 5 years ago
    This is a supercool project! Really loved it
    Can imagine about the amount of work that went into designing the GUI image. Using Nextion display would have made the job little easier as there is a software to design GUI and toggling can be controlled with the serial interface.
  • airbornesurfer
    airbornesurfer over 5 years ago
    Another awesome clock project! I may have to build one of these myself!
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to jenniferl
    Thank you Jennifer!
    That is a good idea for the TFT, One of the reasons I did not add any TFT functionality, was that I could not think of a great use for it since the encoder did everything I needed. It could also take you to the TZ selection screen in context to change it. Also, that would require a lot more code, hah
    That is awesome! If you run into anything or have questions please feel free to ask away here on this thread, I will keep an eye on it. Key tip: Make sure you get the same IC and 7seg displays. I will also see about getting a schematic together to post. Good luck!
    -Kaleb
  • jenniferl
    Very nice, Kaleb!  I like the "why buy one when you can build it" philosophy!!  Did you consider adding AM/PM indicators for the two external displays?  It looks like there might be room on the associated information areas on the TFT.  Also, I wondered about adding some functionality using the touch-screen capabilities already present in the TFT.  Maybe a single tap on one of the timezones moves it to the top external display, and a double tap moves it to the bottom display.  It would require significantly more programming, I guess.  The possibilities, though, are plentiful!
    Thanks for sharing!  You've inspired me to build this project!!
    Jennifer
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to mayermakes
    Hah!
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to DAB
    Thanks DAB!
    -Kaleb
    Nice build.
  • mayermakes
