Project Videos
  • Project Videos
Project Videos
Documents IoT Arduino NTP World Clock with SPI Display -- Episode 476
EMI-Reduction-Techniques
  • Date Created: 8 Dec 2020 7:51 PM Date Created
  • Last Updated Last Updated: 11 Dec 2020 8:24 AM
  • Views 5729 views
  • Likes 10 likes
  • Comments 8 comments
I work with people in many different time zones, and have always wanted an ‘at a glance’ world clock so I can see what time it is in their time zone. But I want mine to be configurable and synchronized with NTP, so I am going to build it!
Supplemental Content:
  • Download code from Github:  https://github.com/KalebClark/ArduinoClock
Bill of Material:
ARDUINO NANO 33 IOT DEV BRD, ARM CORTEX-M0+ MCU ARDUINO 1 Buy Now
VISHAY 7 Segment LED Display, Multiplex Mode, Green, 20 mA, 2 V, 4 mcd, 4, 10 mm VISHAY 2 Buy Now
ADAFRUIT Add-On Board, PiTFT Plus Raspberry Pi HAT, 3.5" TFT Screen, 480 x 320, Capacitive Touchscreen ADAFRUIT 1 Buy Now
TRIPP-LITE USB Cable, Type A Plug to Micro Type B Plug, 3 m, 10 ft, USB 2.0, Black TRIPP-LITE 1 Buy Now
BOURNS Rotary Encoder, Mechanical, Incremental, 24 PPR, 24 Detents, Vertical, With Momentary Push Switch BOURNS 1 Buy Now
LED DISPLAY DRIVER, 8 DIGIT, DIP-24 MAXIM INTEGRATED 1 Buy Now
Additional Parts:
Product Name
Small Proto board
10kohm Resistor
NTPWorldClock_Resources.zip
Kaleb_013-STL-Files.zip
element14 presents
element14 presents  |  About Kaleb |  Project Videos
  • vishay
  • kaleb
  • e14presents_kalebclark
  • clock
  • arduino nano
  • tft
  • diy
  • seven segment display
  • ntp
  • friday release
  • time
  • bourns
  • adafruit
  • e14p_KC
  • friday_release
  • tripp-lite
  • mayermakes
    mayermakes over 5 years ago +2
    mid of the episode ..suddenly " are you an Engineer or maker?" YES..thats me..no really thats me totally cought me off guard..answering to my own voice.
  • jenniferl
    jenniferl over 5 years ago +2
    Very nice, Kaleb! I like the "why buy one when you can build it" philosophy!! Did you consider adding AM/PM indicators for the two external displays? It looks like there might be room on the associated…
    DAB over 5 years ago +1
    Nice build. DAB
  • jenniferl
    Very nice, Kaleb!  I like the "why buy one when you can build it" philosophy!!  Did you consider adding AM/PM indicators for the two external displays?  It looks like there might be room on the associated information areas on the TFT.  Also, I wondered about adding some functionality using the touch-screen capabilities already present in the TFT.  Maybe a single tap on one of the timezones moves it to the top external display, and a double tap moves it to the bottom display.  It would require significantly more programming, I guess.  The possibilities, though, are plentiful!
    Thanks for sharing!  You've inspired me to build this project!!
    Jennifer
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to jenniferl
    Thank you Jennifer!
    That is a good idea for the TFT, One of the reasons I did not add any TFT functionality, was that I could not think of a great use for it since the encoder did everything I needed. It could also take you to the TZ selection screen in context to change it. Also, that would require a lot more code, hah
    That is awesome! If you run into anything or have questions please feel free to ask away here on this thread, I will keep an eye on it. Key tip: Make sure you get the same IC and 7seg displays. I will also see about getting a schematic together to post. Good luck!
    -Kaleb
  • KalebTheMaker
    Thank you Jennifer!
    -Kaleb
