Project Videos
  • Project Videos
Project Videos
Documents Make The Ultimate Phone Charging Camping Flashlight -- Episode 486
  • Date Created: 16 Feb 2021 6:05 PM Date Created
  • Last Updated Last Updated: 19 Feb 2021 8:24 AM
  • Views 4751 views
  • Likes 9 likes
  • Comments 17 comments
Carrying around a rechargeable torch and power bank when out and about at night or whilst camping? Why not combine them into one easy to carry unit? Here’s how I do it.
Supplemental Content:
  • Episode 486: Bonus Content: Make The Ultimate Phone Charging Camping Flashlight
Bill of Material:
PICPALNB126 Rechargeable Battery, 14.4 V, Lithium Ion, 3.35 Ah, 18650, Connector Panasonic 1 Buy Now
CC094 USB Connector, USB Type A, Socket, 2 Ways, Chassis Mount, Horizontal Velleman SA 1 Buy Now
0523405 Carpoint Socket Outlet, 12V Carpoint 1 Buy Now
48-782 Marine Grade Weatherproof 12V Cigarette Lighter Socket Philmore 2 Buy Now
Connector Housing, KK 254 2695, Receptacle, 2 Ways, 2.54 mm Molex 1 Buy Now
08-50-0032 Contact, KKRegistered 254, KK 254 4809 Series, Socket, Crimp, 22 AWG, Tin Plated Contacts Molex 1 Buy Now
Quick Disconnect Terminal, FASTON 250 Series, Female Quick Disconnect, 6.35mm x 0.81mm AMP – TE CONNECTIVITY 1 Buy Now
1614 10 DC Power Connector, Jack, 2 A, 2.35 mm, Panel Mount, Solder Lumberg 1 Buy Now
LED Housing, 9.5 mm x 12.5 mm, Black, Plastic, 5mm / T1 3/4 LEDs KINGBRIGHT 7 Buy Now
Pushbutton Switch, 20.2 mm, DPST, Off-On, Round Raised, Black Multicomp Pro 2 Buy Now
Pushbutton Switch, 20.2 mm, DPST, Off-(On), Round Raised, Black Multicomp Pro 1 Buy Now
Additional Parts:
Product Name
27W 12V DC Round LED Work Lamp
Plastic box with handle
UltimateFlashlightResources.zip
element14 presents
element14 presents  |  About Katie |  Project Videos
  • traveling
  • katie dumont
  • carpoint
  • molex
  • usb power bank
  • e14p_KD
  • lumberg
  • e14presents_kdumont
  • panasonic
  • te connectivity
  • velleman
  • kingbright
  • lithium ion charger
  • katie
  • multicomp
  • torch
  • camping
  • rechargeable battery
  • night walks
  • friday_release
  • hifromkatie
    hifromkatie over 5 years ago in reply to baldengineer +4
    I came across the buttons whilst searching, but they are really neat. Going to keep them on my go to parts list! The OpenSCAD is a bit of a fragile relationship, when I get my head around an idea then…
  • baldengineer
    baldengineer over 5 years ago +2
    Unexpected OpenSCAD (@ 9:20)! You are definitely more skilled with it than I am. I can, just barely, edit pre-existing designs. Also, I didn't know Multicomp Pro had those panel mount push buttons. I need…
  • koudelad
    koudelad over 5 years ago +2
    Nice build! The output luminosity is huge I was also impressed by the OpenSCAD. Do you have an estimation of the battery life while powering just the lamp? I would suggest to do some basic (PWM?) regulation…
  • hifromkatie
    hifromkatie over 5 years ago in reply to kmikemoo
    Yes, my first thought was room for charging cables, but turns out there's enough room for the phone and a sandwich & snacks!
  • hifromkatie
    hifromkatie over 5 years ago in reply to koudelad
    Thanks.
    I've done some quick calculations it worked out as drawing 19.46W whilst the torch was illuminated (Interesting, seeing as the LED unit claims 27W). The battery is 48Wh, so should be around 148 minutes of battery life.image
    Good call with PWM idea, I was aiming to see how bright I could make it, but it wouldn't be a bad idea to reduce it down. Having it selectable could be useful.
    DAB over 5 years ago
    Nice build.
    I might have added a shoulder strap just for convenience.
  • kmikemoo
    kmikemoo over 5 years ago
    Nice job, hifromkatie. Even some space to keep the phone (or some snacks).  Very handy.  While it might seem intuitively obvious to many, I probably liked the lamp at the hinge the most.  I don't know that I would have got that right - but I will now.
  • koudelad
    Nice build! The output luminosity is huge image I was also impressed by the OpenSCAD.
    Do you have an estimation of the battery life while powering just the lamp? I would suggest to do some basic (PWM?) regulation (100 %. 66 %, 33 % or similar) - not only to save battery life, but also not to get blind image
  • hifromkatie
    The OpenSCAD is a bit of a fragile relationship, when I get my head around an idea then it's great, but there was lots of moments whilst designing that insert that ended up in head against desk and screams of frustration.
    I think I should probably get my university Engineering Mathematics textbook back off the shelf for some revision.
  • baldengineer
    Also, I didn't know Multicomp Pro had those panel mount push buttons. I need to pick up a couple of those for a project idea.
