      • Japan
      • Vietnam
Project Videos
  • Project Videos
Project Videos
Documents Build An FPV Rover with Raspberry Pi -- Episode 489
  • Date Created: 9 Mar 2021 4:15 PM Date Created
  • Last Updated Last Updated: 12 Mar 2021 8:24 AM
  • Views 5519 views
  • Likes 14 likes
  • Comments 18 comments
Clem dropped his favorite screwdriver and instead of using a broomstick to retrieve it, like a sane person, he builds a WiFi controlled Raspberry Pi based robot with a live video feed using the HQ Camera to retrieve it. Along the way he builds an easy to use robotics add-on for the Pi that you at home to build your own awesome robots!
Supplemental Content:
  • Episode 489: Bonus Content: 3D Design
  • Episode 489: Bonus Content: Code
  • Episode 489: Bonus Content: Full Reveal
  • Episode 489: Bonus Content: How to Find the STOP Signal on a Continuous Rotation Servo
Bill of Material:
RPI 6mm Wide Angle Lens for Raspberry Pi High Quality Camera, 3MP, CS-Mount RASPBERRY-PI 1 Buy Now
3D Printer Filament, 1.75mm Dia, Olive Green, PLA, 1 kg MULTICOMP 1 Buy Now
High Quality Camera, Raspberry Pi, 12.3 MP, RAW12/10/8 and COMP8 Output, 12.5 mm to 22.4 mm Focus RASPBERRY-PI 1 Buy Now
Single Board Computer, Raspberry Pi 3 Model A+, BCM2837B0 SoC, Dual-Band WiFi, IoT RASPBERRY-PI 1 Buy Now
MEMS Module, MotionTracking Series, 3-Axis Gyroscope/Accelerometer, ±16g, 2.375 V to 3.46 V, QFN-24 INVENSENSE 1 Buy Now
Servo Motor, Continuous Rotation, 6 V, 47 in-oz, 60 rpm ADAFRUIT 4 Buy Now
Analogue to Digital Converter, 12 bit, 3.3 kSPS, Differential, Single Ended, I2C, Single, 2 V TEXAS INSTRUMENTS 1 Buy Now
LED Driver, 16 Outputs, 2.3V to 5.5V In, 400mA Out, TSSOP-28 NXP 1 Buy Now
Additional Parts:
Product Name
PCB from Aisler.net
Headers 2.54mm
Screw terminal
Deans T connector
Madness
FPC Tank_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • invensense
  • raspberry pi webcam
  • fpv robot
  • clem
  • Analogue to Digital Converter
  • hq camera projects
  • e14presents_mayermakes
  • robot
  • rpi moving camera
  • uv4l
  • accelerometer
  • servo
  • raspberry pi
  • robot project
  • wifi robot
  • gyroscope
  • multicomp
  • hq camera
  • nxp
  • adafruit
  • friday_release
  • mayermakes
  • e14p_CMM
  • ntewinkel
    ntewinkel over 4 years ago in reply to mayermakes +7
    Great robot tank, Clem! Next step, you ask? An easy step would be to add spotlights on the front to see under the cabinets a little more clearly. For a bigger project, you could of course add a robot arm…
    DAB over 4 years ago +4
    Nice build Clem. Have you considered setting up the tank with a metal detector? DAB
  • norbixin
    norbixin over 4 years ago +2
    Great video. Will we get the PCB design bonus video?
  • davedarko
    davedarko over 4 years ago
    Great episode! I always enjoy watching robot missions like rctestflight has so many of them.
    So Stephen Hawes did an upgrade on his PNP a bit ago and used this raster of holes peak array like Bunnie Huang did. 30mm grid and a 30mm grid offset and diagonal. This might come in handy if you want to mount things on the inside and on the outside as well.
    https://youtu.be/jyicTLhCzh8?t=140
    This robot looks like it wouldn't mind to drive on it's head, but that switch could become a liability then image
    The servos mounted like that should also allow for a robot with legs easily, just looking at my petoi bittle. Cool thing, hoping for lots of robots to be posted here!
  • mayermakes
    mayermakes over 4 years ago in reply to davedarko
    Yes such a grid would be a good standard interface for a robotic plattform ! neat idea!
    Also the robots shape is intended to keep it driving even if it flips upside down!
    provisions on the bot for an MPU6050 allow to adapt the controlls and Camera output rotation on the fly in case it flips over!
  • mayermakes
  • davedarko
    davedarko over 4 years ago in reply to mayermakes
    "Also the robots shape is intended to keep it driving even if it flips upside down!" - yeah thought as much, but that switch might turn lethal then image
