Project Videos
  • Project Videos
Project Videos
Documents Keyboard Shortcuts Keypad with Raspberry Pi Pico -- Episode 494
  • Date Created: 12 Apr 2021 4:33 PM Date Created
  • Last Updated Last Updated: 16 Apr 2021 7:24 AM
  • Views 14945 views
  • Likes 14 likes
  • Comments 61 comments
Frequently used programs which have shortcuts/macros to save you time, but forget what they are? Here's a shortcut keypad for quick and easy access, with a helpful screen to remind you where the location of each.
Bill of Materials
Raspberry Pi Pico Raspberry Pi 1 Buy Now
4D systems PIXXILCD-25P4 4D Systems 1 Buy Now
Rotary Encoder PEC12R-4225F-S0024 BOURNS 1 Buy Now
MX1A-11NW Tactile Switch CHERRY 12 Buy Now
2.85mm BLACK PLA Filament FILAMENTIVE 1 Buy Now
Additional Parts
Product Name Manufacturer Quantity
Keycaps n/a 12
wiring.txt :
Switches (all)
Pico					To
GP0 (Pin1)		SW1(pin1)
GP1 (Pin2)		SW2(pin1)
GP2 (Pin4)		SW3(pin1)
GP3 (Pin5)		SW4(pin1)
GP4 (Pin6)		SW5(pin1)
GP5 (Pin7)		SW6(pin1)
GP6 (Pin9)		SW7(pin1)
GP7 (Pin10)		SW8(pin1)
(Pin11)				Screen(pin??)
(Pin12)				Screen(pin??)
GP10 (Pin14)		SW9(pin1)
GP11 (Pin15)		SW10(pin1)
GP12 (Pin16)		SW11(pin1)
GP13 (Pin17)		SW12(pin1)
Pin1 as above
Pin2 to +3.3v (Pico pin 36)
Rotary Encoder
PinA					Pico GP14 (Pin19)
PinC					GND (Pico Pin 38)
PinB					Pico GP15 (Pin20)
Pin1					Pico GP16 (Pin21)
Pin2					+3.3v (Pico pin 36)
See datasheet for pin labeling on rotary encoder
But looks like this:
		1		2
	A		C		B
Screen using gen4 InterfaceBoard
+5V				+5V Pico(Pin40)
TX				Pico UART1 RX/GP9 (Pin12)
RX				Pico UART1 TX/GP8 (Pin11)
GND				GND (Pico Pin 38)
RES				Not Connected
Code and 3D Printable STL Files
  • Episode 494 Resources
element14 presents
element14 presents  |  Katie Dumont's VCP Profile |  Project Videos
  • shortcut keypad
  • rpi pico
  • shortcuts
  • keypad
  • e14presents_kdumont
  • macros
  • e14presents_katiedumont
  • time saving
  • friday_release
  • baldengineer
    baldengineer over 5 years ago +9
    Raise your hand if you'd like to see an OpenSCAD tutorial from Katie!
  • airbornesurfer
    airbornesurfer over 5 years ago in reply to baldengineer +4
  • adamsoileau1
    adamsoileau1 over 5 years ago +2
    Fantastic project! This seems like it would be incredibly useful in day-to-day work. Also, nice usage of the Pico! I've been needing to buy one and try it out
  • chelli
    chelli over 5 years ago
    This is great! Can I program long macros similarly? Entire words?
    Did I understand correctly that there’s no need to download software onto the machine I plug it into?
    that would mean I can use it at work.
    you’re awesome
  • hifromkatie
    hifromkatie over 5 years ago in reply to liamhoffen
    Sorry that there's been a mix up in the files, glad you sorted it though. I'll check what I've got locally against what has been uploaded and get the correct files here. Thanks for making me aware.
    Hope your version comes out well, would be great to see if when your finished.
  • liamhoffen
    liamhoffen over 5 years ago in reply to liamhoffen
    Following Karl's lead, I installed OpenSCAD, fumbled through and worked out what I needed to do.  However, I must believe that many will have the issues we did.
  • liamhoffen
    liamhoffen over 5 years ago in reply to karl0ss
    I loved the tutorial, and the case design is quite nice.  I've printed the key plate and back plate, but I have the same problem here...the case stl file is the key plate, and there's no knob stl file.  I don't have any tools or experience with open SCAD, so I'm hopeful the STL files can be updated as a complete set for the project.
  • hifromkatie
    hifromkatie over 5 years ago in reply to neilk
    Thanks, it was my first project using circuit python, think I may give it a go on some more projects in the future.
  • hifromkatie
    hifromkatie over 5 years ago in reply to koudelad
    Really glad to hear you'll be able to use some of the ideas to help you on your other project
  • karl0ss
    karl0ss over 5 years ago in reply to karl0ss
    Not to worry, i managed to export the stls needed from the scad file
  • karl0ss
    Great project and idea, having pulled down the zip file, it would seem that
    case_v1.03.stl and key_plate.stl
    are both the key_plate?
    Thanks
  • Workshopshed
    Workshopshed over 5 years ago
    Great project. I am a fan of OpenSCAD but it has been a while since I used it. Here's a couple of things I created using it.
    It gets really useful when you start using the functionsimageimage
    https://www.workshopshed.com/2016/07/openscad-two-types-function/
    If you like Python and like the idea of creating 3D objects with code then there is also https://github.com/SolidCode/SolidPython
  • neilk
    neilk over 5 years ago
    Great project, Katie! Good to see the Pico being exploited and love the use of circuit python!
    Thanks for sharing
    Neil
