      • Japan
      • Vietnam
Project Videos
  • Project Videos
Project Videos
Documents Super 8 Camera Digitizer -- Episode 505
  • Date Created: 29 Jun 2021 5:49 PM Date Created
  • Last Updated Last Updated: 2 Jul 2021 7:24 AM
  • Views 9535 views
  • Likes 13 likes
  • Comments 21 comments
In a previous episode, Clem has built a proof of concept to convert a Super 8 film camera into a digital camcorder without any modifications to the camera itself. Many of you asked for a Kit or if a digital drop-in Film Cartridge replacement was possible! Finally, Clem has the chance to revisit the project and uses the New Raspberry PI compute Module 4 and the HQ camera module to build a crazy compact cartridge that is a major stepping stone towards a real product! And during the project, he even had to start his own 3D printer Resin brand just to obtain a material that is up to the task for this project!
Bill of Material:
AMPHENOL ICC FFC / FPC Board Connector, 1 mm, 15 Contacts, Receptacle, FCI 58RF SFW-R series, Surface Mount, Top AMPHENOL ICC 1 Buy Now
MULTICOMP PRO FFC / FPC Cable, 15 Core, 1 mm, Same Sided Contacts, 1.97 ", 50 mm, White 1 Buy Now
HIROSE(HRS) Mezzanine Connector, Receptacle, 0.4 mm, 2 Rows, 100 Contacts, Surface Mount, Phosphor Bronze HIROSE(HRS) 2 Buy Now
Raspberry Pi Compute Module 4, with 4GB RAM, 32GB eMMC, Wireless, BCM2711, ARM Cortex-A72 RPI 1 Buy Now
molex Board Connector FFC / FPC Board 1 mm, 15 Contacts, Receptacle, Easy-On 52610, Surface Mount molex 2 Buy Now
molex Premo Flex Jumper FFC / FPC Cable, 14 Core, 1 mm, Same Sided Contacts, 12 ", 305 mm, White molex 1 Buy Now
Additional Parts Manufacturer Quantity
Glas prism 10x10mm
MAYER MAKES Engineering Resin 1kg
Super 8_Resources.zip
element14 presents
element14 presents  |  About Clem |  Project Videos07W6532
  • clem
  • raspberry pi compute module
  • pi compute
  • super 8
  • e14presents_mayermakes
  • photography
  • compute
  • raspberry pi 4
  • raspberry pi
  • amphenol
  • multicomp
  • hirose
  • raspberry pi 4 compute module
  • friday_release
  • compute module
  • mayermakes
  • module
  • e14p_CMM
  • mayermakes
    mayermakes over 4 years ago in reply to dougw +6
    Thanks for asking. I call it " MAYER MAKES Engineering Resin ". As seen in the video it is extremely tough and impact resistant. In my quick iterations I often use resin prints that I oversize and while…
  • fmilburn
    fmilburn over 4 years ago +4
    Material science, mechanical, optical, electronic, and power challenges. That is really Impressive work on an interesting and super challenging project.
  • ralphjy
    ralphjy over 4 years ago +3
    That's an incredible packaging accomplishment - great electromechanical design (plus the optical path). Makes me want to try a resin printer . It seems like trying to get that much power into an unmodified…
  • ralphjy
    That's an incredible packaging accomplishment - great electromechanical design (plus the optical path).  Makes me want to try a resin printer image.
    It seems like trying to get that much power into an unmodified camera is problematic (as you mentioned that you'll need to design something for heat dissipation).  Maybe you need to try a lower power design.  What pixel resolution do you think is needed for Super 8?
  • mayermakes
    mayermakes over 4 years ago in reply to ralphjy
    thanks, Yes heat dissipation is still another concern.
    I suspect I could dissipate enough heat over the cameras chassi/the case if conductive enough.
    Also using a lower power approach might be possible..BUT I really wnat to get the best possible picture and the most compact solution I found so far is the one showen here.
    of course if we get into totally custom engineering there is abetter way, but I'm not quite ready for that yet, and if I can make this happen with "standard" parts. it is easier to produce in the small batches I count on.
    I would not want to go below HD 1080p, as filmgrain often gets mistaken for low resolution by consumers. What I want to achieve is make the characteristics of the camera usable again for filmmakers  and therefore 1080p is the minimum.
    beacon_dave over 4 years ago in reply to mayermakes
    "...What I want to achieve is make the characteristics of the camera usable again for filmmakers  and therefore 1080p is the minimum... "
    If you dropped down to 8MP, then you could perhaps use the IMX219 imager found in the V2 camera module. This has the advantage of being able to be unplugged and extended avoiding the need for the additional optics. However it is a smaller 1/4" format imager.
    https://www.arducam.com/product/b0186-arducam-imx219-sensor-extension-cable-raspberry-pi-nvidia-jetson-nano/
    A lower resolution 2MP IMX291 imager may have lower light and wider dynamic range performance, which may be of interest to some filmmakers over the resolution. It is a 1/2.8" format imager.
    For those interested, Edmund Optics have a load of interesting videos on digital imaging aspects e.g.:
    Lens Types, Resolution, and Sensor Coverage - YouTube
