Project Videos
  • Project Videos
Project Videos
Documents Super 8 Camera Digitizer -- Episode 505
  • Date Created: 29 Jun 2021 5:49 PM Date Created
  • Last Updated Last Updated: 2 Jul 2021 7:24 AM
  • Views 11451 views
  • Likes 14 likes
  • Comments 21 comments
In a previous episode, Clem has built a proof of concept to convert a Super 8 film camera into a digital camcorder without any modifications to the camera itself. Many of you asked for a Kit or if a digital drop-in Film Cartridge replacement was possible! Finally, Clem has the chance to revisit the project and uses the New Raspberry PI compute Module 4 and the HQ camera module to build a crazy compact cartridge that is a major stepping stone towards a real product! And during the project, he even had to start his own 3D printer Resin brand just to obtain a material that is up to the task for this project!
Bill of Material:
AMPHENOL ICC FFC / FPC Board Connector, 1 mm, 15 Contacts, Receptacle, FCI 58RF SFW-R series, Surface Mount, Top AMPHENOL ICC 1 Buy Now
MULTICOMP PRO FFC / FPC Cable, 15 Core, 1 mm, Same Sided Contacts, 1.97 ", 50 mm, White 1 Buy Now
HIROSE(HRS) Mezzanine Connector, Receptacle, 0.4 mm, 2 Rows, 100 Contacts, Surface Mount, Phosphor Bronze HIROSE(HRS) 2 Buy Now
Raspberry Pi Compute Module 4, with 4GB RAM, 32GB eMMC, Wireless, BCM2711, ARM Cortex-A72 RPI 1 Buy Now
molex Board Connector FFC / FPC Board 1 mm, 15 Contacts, Receptacle, Easy-On 52610, Surface Mount molex 2 Buy Now
molex Premo Flex Jumper FFC / FPC Cable, 14 Core, 1 mm, Same Sided Contacts, 12 ", 305 mm, White molex 1 Buy Now
Additional Parts Manufacturer Quantity
Glas prism 10x10mm
MAYER MAKES Engineering Resin 1kg
Super 8_Resources.zip
element14 presents
element14 presents  |  About Clem |  Project Videos07W6532
  • clem
  • raspberry pi compute module
  • pi compute
  • super 8
  • e14presents_mayermakes
  • photography
  • compute
  • raspberry pi 4
  • raspberry pi
  • amphenol
  • multicomp
  • hirose
  • raspberry pi 4 compute module
  • friday_release
  • compute module
  • mayermakes
  • module
  • e14p_CMM
  • mayermakes
    mayermakes over 5 years ago in reply to dougw +6
    Thanks for asking. I call it " MAYER MAKES Engineering Resin ". As seen in the video it is extremely tough and impact resistant. In my quick iterations I often use resin prints that I oversize and while…
  • fmilburn
    fmilburn over 5 years ago +4
    Material science, mechanical, optical, electronic, and power challenges. That is really Impressive work on an interesting and super challenging project.
  • ralphjy
    ralphjy over 5 years ago +3
    That's an incredible packaging accomplishment - great electromechanical design (plus the optical path). Makes me want to try a resin printer . It seems like trying to get that much power into an unmodified…
    beacon_dave over 5 years ago in reply to mayermakes
    you've not harvested the energy available from the cassette drive motor yet image
  • mayermakes
    mayermakes over 5 years ago in reply to javagoza
    Just looking at the datasheet, this is indeed a good candidate!
    haven heard of that brand before.
    thank you very much for the tipp!
  • mayermakes
    mayermakes over 5 years ago in reply to davedarko
    thanks for the hint! its also a good oportunity for myslef to learn some propper enginereing ways.
  • mayermakes
    Hey Doug, Yes it captures video when powered externally, but as you can imagine its just a blob as the light is not focused, haven't tried to jerryrig something just to see apicture, knowing its working was good enoug hfor me.
    For a moment I thought about other cells, but i had no other option than the 1050mah Lipo for size reasons.
    The culprit is in the ability to deliver enough current while pushing it to 5V(5,2V)
  • mayermakes
    mayermakes over 5 years ago in reply to fmilburn
    Thanks Frank, yes this is really challenging, but those are talso the priojects that keep my interest the longest..hence I made asecond version.
  • mayermakes
    wohoa that is abrave idea! I like your thinking.
    But unfortunately there are  problems I see with it:
    induction charging has alot of power loss so not very efficient.. the units needs asteady 3amps to be perfectly stable which I think vastly surpasses the capabilities of current systems without getting dangerous.
    A lot of Super8 cameras are built like faraday cages, so I'd imagine it wont work on some models.
    nevertheless thanks for yopur ideas, maybe the next one is just the the exact one that helps finishing it!
  • javagoza
    javagoza over 5 years ago
    Maybe this can be an option
    Integrated USB TYPE-C Power Bank System-On-Chip with 3A charger, 3.1A discharger
    It integrates a boost converter, a Li battery charger management system, a battery state of charge indicate controller, and built-in TYPE-C protocol
    IP5312 boost 4A
    http://www.injoinic.com/wwwroot/uploads/files/20200221/a7a6128e03ee193cf35e48b28e3df9df.pdf
  • davedarko
    davedarko over 5 years ago
    Lovely outcome! You should talk to Christos from Burgduino, he's building a beefy switching PSU and has other projects around that.
    You probably want to find out what the system is consuming in general, spec the needs so you can give some data to work with.
    dougw over 5 years ago
    Great project.
    Can you jury rig a lens to see if the cartridge captures video?
    NiCd delivers more current than Li-Po although it may not be acceptable for other reasons.
  • fmilburn
